Can only see emails no later than two weeks old! HELP!
rdunlap
Exchange Server 2010
Hello there. We use Outlook 2010 and Exchange 2010 and I am having an issue with one user. She called yesterday to tell us that she was looking at her inbox and she noticed that she couldn't see any email after two weeks old. This user uses two different computers, one at her desk and then one at the front secretary desk where she sits about 2 days a week.
I then checked to see if she had any filters on, even started outlook.exe /cleanviews, /cleanrules, and /safe and still couldn't see past two weeks. I then checked to see if cache mode was checked and it was not on either computer. Checked her deleted folder and there was nothing in there but then did a restore and there was tons of stuff in there, so I restored it all because she said that it looked like it was the stuff but I don't think it was. Anyways, the restore didn't work and there are still only two weeks of emails in her inbox. She's one of the few people here that go through all her emails and delete a lot of them and put some in folders that she really needs to keep.
I then checked around the other folders that she has and there were emails from way back, even going back years. Just to make sure, I enabled her OWA access and signed into her account on there and it had the same stuff that her outlook has so I don't think it's application related.
I'm wondering if there is anything else that I can check that could be causing this issue. I would be very appreciative for any help that can be offered.
If you have any questions for me please let me know.
rdunlap
I believe I did, but where would I check this to make sure?
rdunlap
I just checked and verified that this is not an option. There is no autoarchive tab in the properties menu. It is disabled through our exchange server. What else could be the issue?
rdunlap
Ok, so here's another little tidbit of information. On one of the computers that she was working on, she was running on Cache Mode and one of our techs actually unchecked the box and it seems after he did that the emails went away to just two weeks worth.
I checked her computers and the outlook data files are different sizes. The one on her main computer is over 6GB but not sure why when I kick it into cache mode it doesn't fill her inbox up with tons of messages. I checked the other folders too and nothing is coming in there. I've done closing out to restarting the computer after putting it into cache mode and nothing seems to happen. 6GB seems huge for a data file for outlook and there should be stuff pouring in from there.
R Can only see emails no later than two weeks old! HELP! Exchange Server Administration 6
A Record opened emails for reopening later Using Outlook 2
A Record opened emails for reopening later Outlook VBA and Custom Forms 16
D Wrong email address in Outlook 2003 "From" tab in new outgoing emails Using Outlook 1
witzker How to find all emails from and to a contact in OL 2019 Using Outlook 6
R Sent emails show iCloud mail account not the alias Using Outlook 1
J how to stop junk emails from *.onmicrosoft.com ? Using Outlook 0
M All fonts in Outlook emails display with exaggerated character spacing Using Outlook 1
L Images not displaying in emails sent to self Using Outlook 2
C Icons (arrows) not showing on emails forwarded or replied to Using Outlook 5
U Approving Emails from iPhone Using Outlook 0
T Outlook creating unwanted tasks in Tasks and Todo from emails Using Outlook 1
Horsepower Moving emails between folder Outlook for Mac Outlook Wishlist 8
B Outlook 2016 Outlook crashes when trying to print certain emails Using Outlook 5
L IMAP Emails Disappear Using Outlook 0
D Duplicate Emails on Phone and Tablet Using Outlook 0
C Multiple emails Using Outlook 8
Phillip Bit.ly emails Using Outlook 1
G Alerting on missed emails in conversation Outlook VBA and Custom Forms 1
P Outlook for Mac - emails are not sent out beginning last week Using Outlook 1
