Contact's Notes field not transferring when forwarding vCard
Eduardo
Outlook 2013 64 bit
Hello All,
Sorry if this has already been answered, I searched around the Forums and did not find an answer.
I have Outlook 2013 at Home, when my Wife updates a Contact and sends it to me (at Work, Outlook Home and Business 2010) using the "Forward as a vCard" option, I get the contact info, but a blank "Notes" field. Any ideas or settings that can change that functionality so the entire Contact Record is included?
Eduardo
Eduardo
Outlook 2013 64 bit
Thanks Diane, I understand the first part of your answer, but I'm not clear on what you mean by: "if its inserted as an outlook contact, it should include the notes field." Can you clarify/expand?
She is forwarding it as a vcard - this is supported by any application that can open vcards. If its sent as an outlook item, it can only be opened by outlook and should include the notes field. forward as an outlook contact or use the Insert > Outlook item to send it.
Forward as vcard creates a smallish attachment with the vcf extension, forward as outlook contact will have a larger attachment and no extension.
johng34
Outlook 2013 64 bit
There is a way, but only one contact at a time. If you open a contact, then do a file-> save as -> (specify a vCard Files (*.vcf) type, it WILL have the "Notes" field in it.
I also am looking for a way to save multiple contacts with the "Notes" field. :-(
Outlook doesn't support multi-cards, so you'll need to use an addin or a macro to do it from outlook.
K Contact notes field replicating Using Outlook 6
P Select image in contact notes field and save as jpg Outlook VBA and Custom Forms 6
M Customize Comments / Notes Section time stamp on Contact Records BCM (Business Contact Manager) 0
P mailto replication in Outlook Contact Notes Using Outlook 4
C Outlook Custom Contact Form Attach Files in new notes fields Outlook VBA and Custom Forms 3
J Changing Contact Notes Font Outlook VBA and Custom Forms 9
M Bulk Edit contact notes BCM (Business Contact Manager) 1
M Notes / Comments in Contact - Text is there but not indexed or searchable BCM (Business Contact Manager) 0
A Searching for text in Contact notes Using Outlook 2
D Outlook Contact Notes show previous history with strike through. Using Outlook 1
Y Contact Notes Issue Using Outlook 6
F Text Format Change - Bulk Edit Contact Notes Using Outlook 2
Q More than one Notes section in custom contact forms Outlook VBA and Custom Forms 1
F Outlook 365 No scroll bars in Contact Using Outlook 2
J "Contact" button in Journal entry Using Outlook 1
witzker How to find all emails from and to a contact in OL 2019 Using Outlook 6
O Outlook 365 - How to create / copy a new contact from an existing one? Using Outlook 3
M Contact suggestion Using Outlook 2
witzker Open Contact missing in Outlook 2019 Using Outlook 2
R Time for another article on contact cards? Using Outlook 0
A Sending contact vcards sends older version instead of updated version Using Outlook 4
M Contact photos are distorted Using Outlook 0
C Outlook Contact Manager - A viable successor? BCM (Business Contact Manager) 7
N Contact display as Using Outlook 2
