Outlook body to word document
Joey Jeff
Outlook 2013 64 bit
Hello! There are about a million references on how to send an email from a word document, but nearly none on how to create a word document from an email automatically. I need a script that, using rules on outlook, reads a certain word in the subject line, and then automatically creates a word document with that emails body. I am incredibly new at macros and have no idea how to do this, so if you can spare a little extra time on how the code works i would be eternally grateful. Thanks!
Forum Admin
You either need to use a run a script rule to copy the mail body or save the message as a docx file.
This copies the body to a document
Sub SaveWord(Item As Outlook.MailItem)
   Dim oWord As Word.Application
   Set oWord = CreateObject("Word.Application")
   With oWord
     .Documents.Add
     .Selection.InsertBefore (Item.Body)
     .Visible = True
    Set oWord = Nothing
This macro: http://www.slipstick.com/developer/convert-messages-rtf-format-save-doc-file-type/ - saves messages as a docx file type. It needs tweaked to work in a run a script rule though.
Joey Jeff
Outlook 2013 64 bit
Thanks! Im running into a couple of issues however, it works if i change "Dim oWord As Word.Application" to "Dim oWord As Object" and i have no idea why. When it is the former i get the error "Compile Error: User Type Not Defined". Also, i am running into issues saving the document into a folder. Thanks so much for your response!
Joey Jeff
Outlook 2013 64 bit
I had the both versions of the code "ActiveDocument.SaveAs Filename:='my path'" as well as "ActiveDocument.SaveAs 'My Path" as well as "oWord.Save as 'My Path'", and literally nothing happened. Word just opens and has the text from the email there, but it is not saved.
Joey Jeff
Outlook 2013 64 bit
Yeah, that didnt work either, it just opens the document with the body of the email there, and nothing happens. Also, i tried putting that line under the "with oWord" as ".SaveAs.....", and the document didnt even open at all, literally nothing happened. Thanks for helping me through this, its a bit frustrating haha
Joey Jeff
Outlook 2013 64 bit
Here is my code:
Dim oWord As Object
Dim sName As String
Dim dtDate As Date
sName = Item.Subject
dtDate = Item.ReceivedTime
With oWord
.Documents.Add
.Visible = True
oWord.SaveAs "C:\test\htdocs\worddocuments" & sName & dtDate & ".doc", olRTF
Set oWord = Nothing
First thing off the bat - it's saving it to C:\test\htdocs, with a filename of worddocumentsNameDate.doc
I'll test it next and see if it works here.
Oh, and you need to format the date and check the subject for illegal characters - windows won't save if the name is not valid.
Add this above the oword.saveas line then open the immediate window (on the View menu in the VB Editor) - send a tesat message so you can see what the macro is using for the name.
Debug.Print "C:\test\htdocs\worddocuments" & sName & dtDate & ".doc"
my filename was
C:\Users\dianep\Documents\print\Data Record 7/24/2014 14:42:087/24/2014 11:42:23 AM.doc
(my test message generator creates a message with a subject of "Data Record [Now]", so there are two dates in the filename, the one in the subject and one for the received time. )
I added these lines before With oWord
sName = sName & dtDate
ReplaceCharsForFileName sName, "_"
(and used C:\Users\dianep\Documents\print\" & sName & ".doc" to create the filename)
that turned my files name into
C:\Users\dianep\Documents\print\Data_Record_7_24_2014_14_48_337_24_2014_11_48_35_AM.doc
I'm, not sure why the admin is using the word object - saving the messages as rtf is all you really need to do. Well, it does include the message header - I guess that is why. You need to call more of the word object model if you want to save - the short snippet only opens the document onscreen.
Dim sName As String
Dim dtDate As Date
   Item.BodyFormat = olFormatRichText
Debug.Print "C:\Users\dianep\Documents\print\" & sName & ".doc"
Item.SaveAs "C:\Users\dianep\Documents\print\" & sName & ".doc", olRTF
Private Sub ReplaceCharsForFileName(sName As String, sChr As String)
  sName = Replace(sName, "<", sChr)
  sName = Replace(sName, ">", sChr)
  sName = Replace(sName, "&", sChr)
  sName = Replace(sName, "%", sChr)
  sName = Replace(sName, " ", sChr)
  sName = Replace(sName, "{", sChr)
  sName = Replace(sName, "[", sChr)
  sName = Replace(sName, "]", sChr)
  sName = Replace(sName, "}", sChr)
This version saves just the body, not the header block, but it looks like sh** if the message has HTML links.
Dim oWord As Object
Dim sName As String
Dim dtDate As Date
Debug.Print sName
With oWord
.Documents.Add
.Visible = True
Debug.Print "C:\Users\dianep\Documents\print\" & sName & ".docx"
oWord.activedocument.SaveAs2 FileName:="C:\Users\dianep\Documents\print\" & sName & ".docx", FileFormat:= _
        wdFormatXMLDocument, CompatibilityMode:=15
Set oWord = Nothing
divan Outlook 2007 - Replace email body with custom text Using Outlook 9
K Importing appointment body from excel in outlook 2010 Using Outlook 1
Vijay Kumar Tables in outlook body Outlook VBA and Custom Forms 1
Aussie Looking for Outlook macro to Copy Recipient Names into Email Body Outlook VBA and Custom Forms 3
R Body of email not visible in Outlook Data File Sent Folder Using Outlook 4
H Using Outlook Rules to search for NewLines in message body Using Outlook 1
S Pre populate subject + body + attachment to already open email in outlook 2007 Using Outlook 2
I Outlook Appointments - Setting default text in message body Using Outlook 3
W Outlook body to Excel Document Using Outlook 35
P HTA creating Outlook MeetingItem - need formatted body text Using Outlook 4
M Mail in HTML format can't be sent if url or number is in the body Outlook 2010 Using Outlook 2
L No body text in Outlook 2010 messages Using Outlook 0
S Blank body when replying with an Outlook Form. Using Outlook 21
W Recipients of Outlook messages have characters/words missing in body of message Using Outlook 6
S Clickable link on Outlook HTML Body Outlook VBA and Custom Forms 3
T Can not change email body content on Outlook 2010 Outlook VBA and Custom Forms 2
S HELP: Create Buttons in Outlook Email body or Tool bar Outlook VBA and Custom Forms 1
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 2
@ Outlook Using Outlook 2
