"Instant Search" setting a default view
Neo1
Outlook 2007
Instant search is a life saver and I use it many times a day.
The issue is the search results sort, for some reason the first records displayed (while actively searching) are the oldest. My active In-Box is newest first, aka "received descending".
It would be ok if I could hit "Received" and resort while searching. I cannot; if I touch Outlook during the search it will hang or worse. If I scramble to the bottom of the (ongoing) search results it is like whack-a-mole, my goal-email moves around like a chicken on fire.
I've had 2007 for over two years on this PC - now it has defaulted to "ascending" sort order. Nothing I have changed in the setting seems to stick. It will reset once and the next search is back to the "received ascending".
Neo1
Outlook 2007
Diane
I change the view I have all the time, but never leave it in anything but "date descending". Email and quick response demand it.
Regardless what view I have, or how I default the settings, it sorts ascending, from the oldest. The mystery is that it hadn't been this way before. Not sure what has changed or if I changed it.
Reset the view - this will take it back to the default. Which sort order does it use? (mine uses by date, newest first)
B Instant search with special characters Using Outlook 1
Diane Poremsky Rebuild Outlook's Instant Search Index Using Outlook 0
K Re: Use Instant search to find messages from a contact Outlook VBA and Custom Forms 6
R writing "Instant Search" queries to find User-Defined fields Using Outlook 0
G Outlook 2007 compound (OR) instant search break down Using Outlook 14
B Outlook 2013 instant search fields greyed out Using Outlook 3
L Outlook 2010 Instant Search Pops When I Click Using Outlook 6
S Instant Search in Outlook 2010 Using Outlook 32
S Outlook 2010 Terminalserver Cache Mode Instant Search Using Outlook 4
M How to resize the instant search pane on click on the icon to expand/ Outlook VBA and Custom Forms 1
M How to provide instant search like feature in outlook 2003? Outlook VBA and Custom Forms 1
P Disable Instant Search in Outlook 2007 Outlook VBA and Custom Forms 9
B Search and Find Email by Folder Name Outlook VBA and Custom Forms 0
C Search not accurate, but not indexing Using Outlook 7
H Outlook 2019 intermittent search results Using Outlook 0
H Search Email Header for Content Type Outlook VBA and Custom Forms 1
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
O Advanced search - can I use booleans Using Outlook 3
M Something went wrong and your search couldn't be completed Using Outlook 1
L New Location for the Search Bar Using Outlook 6
King Mustard Sort search groups by amount of items? Using Outlook 1
T Search for incoming e-mails for a specified time range Using Outlook 1
R Search/Jump to a folder by typing its name Outlook VBA and Custom Forms 1
M Sent mail not showing in Sent Items folder; but they can be found with Search Using Outlook 3
A Outlook 2019 having issues with 'people search' and not making suggestions in email To: etc Using Outlook 12
W Search Incomplete Outlook 2016 Using Outlook 5
