auto copy text in mail body to other part of the body
Lars Christiansen
Exchange Server 2010
I am trying to copy text from the email body to another part of the body.
The data could be put into fields the sender can fill out, but I need the same data put in below but as text only. The reason is that I have a system that can read the information as text if it is surrounded by ## and a defined field
Below is an example.
Customer no: 3447 - the value 3447 has to be copied down below as text
##Customer_ID: 3447##
any help is appreciated
Thanks in advance
Regards
Lars
Michael Bauer
I'd probably use the Replace function and replace "Customer no: " by "##Customer_ID: ". Then I'd replace the vbCRLF that most likely marks the end of that row by "##" & vbCRLF.
J how to choose which item alone go to pst ? OR how to auto sync/copy calender Using Outlook 1
R auto-copy from private to public folder Outlook VBA and Custom Forms 3
