Macro won't consistently re-enable
Kim Gilbert
Outlook 2013 64 bit
The following macro takes mail items and converts them to Outlook tasks for several recipients. The messages are automatically generated from Noreply with the subject "ETM - Manufacturing Request No. XXXX"). The problem is that for some recipients, the macro won't re-enable every time.
Sub ConvertMailtoTask(Item As Outlook.MailItem)
Dim oFolder As Outlook.Folder
Set oFolder = Application.Session.GetDefaultFolder(olFolderTasks)
Set objTask = oFolder.Items.Add("IPM.Task.Task with IR and MR Field")
With objTask
.Subject = Item.Subject
.StartDate = Item.ReceivedTime
.DueDate = #1/1/4501#
Dim newAttachment As Outlook.Attachment
Set newAttachment = objTask.Attachments.Add _
(Item, Outlook.OlAttachmentType.olEmbeddeditem)
.Save
Set objTask = Nothing
Thanks so much for y our help!
Kim
Kim Gilbert
Outlook 2013 64 bit
Thank you so much, Diane.
If I place a button on the Outlook ribbon to make it run this code after checking the inbox for the messages, what additional code would I need to add to this code? (I'm in learning mode, as I'm just getting started with using VBA).
witzker Outlook 2019 Macro to answer a mail with attachments Outlook VBA and Custom Forms 2
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 14
G VBA Macro Using Outlook 4
