Reference Text for VBA for outlook
unkit007
I'm a novice to VBA and I'm wondering if anyone can recommend a simple text book to get the ropes. I've been looking around, and it seems the vast majority of material is for excel.
I'm trying to do some pretty basic things like being able to respond to emails with the same questions that always get asked, and set up 7 or 8 buttons with predefined responses.
In Excel, it seems to be as simple as typing what you want to do e.g.
ActiveCell.Value = "this is a test"
In outlook however, I tried "Subbject.Value = "TestingTesting123" but I clearly got the object and the property wrong... i tried the ctrl + space for help, but still nothing.
I'd welcome any suggestions/advice as to what I can read/do
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
K How to reference the selected folder Outlook VBA and Custom Forms 1
N VBA Outlook reference to Excel and assigning category Outlook VBA and Custom Forms 13
M Is there a reference for the valid XML tags and their options? Using Outlook 3
N Providing a reference to incoming mail in outlook 2007 BCM (Business Contact Manager) 2
C Shared Calendar Recipient Reference Outlook VBA and Custom Forms 1
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
S Unable to extract text from an Outlook email message Using Outlook 2
T Original email text not shown when replying or forwarding the email. Using Outlook 9
S Outlook to check for specific text Outlook VBA and Custom Forms 3
B Paste formatted text (bold, underlined and in quotes) Outlook VBA and Custom Forms 1
N Is there an Outlook tool to normalize text for entries that are in ALL CAPS? Using Outlook 2
RangerRick Text Extraction from forwarded messages external Exchange Server Administration 1
S Emails Configured As HTML But Sent As Plain Text Using Outlook 13
W Message Text Using Outlook 1
K Update subject based on text in body Outlook VBA and Custom Forms 3
J Marco in search of text in subject line Using Outlook 8
