VBA to delete declined-meeting
hkchuchu
Outlook 2013 32 bit
Hi, i would like to use VBA to delete the meeting which was declined.
scenario:
Two Users using Outlook 2013 32bits with POP3 accounts (not using exchange).
User A created meeting, invited User B.
User B decline the request, send the decline notice to User A.
User A will receive the notification, but the meeting still place on the Calendar.
When open the meeting, it shown "Attendee responses: 1 declined."
Is it possible run a VBA to delete all this type meeting in User A Calendar?
It would be greatly appreciated if everybody can help.
Leo
Michael Bauer
The item in the inbox is of the MeetingItem type. Call its GetAssociatedAppointment function to get the item from the calendar. Then call that item's Delete method.
P Delete Outlook subfolders using vba ? Outlook VBA and Custom Forms 1
V How to delete mails in deleted items folder by vba? Outlook VBA and Custom Forms 1
