How to call custom email form when sender = x
MHK
I want to create a custom email form and to call this form on certain condition e.g. if sender = x if not then the email should open in Outlook standard inbox email form.
Also want know where to save the custom form to avoid overwriting by Outlook upgrade etc. and if I can use (P2) form for this purpose.
Thanks..
MHK
As to the first issue, create a run-a-script rule to change the MessageClass property of new emails when the condition is met.
Thanks Michael,
Could you pl give some more detail may be with an example for this solution?
Michael Bauer
Add this to the ThisOutlookSession module, then create a rule to call it:
public sub WhatEver(Mail as outlook.mailitem)
mail.messageclass="name of your custom form"
mail.save
end sub
D Create additional custom flag descriptions (other than Send E-Mail, Call etc.) Using Outlook 1
S How to call a procedure from a custom command bar in Outlook 2007 Outlook VBA and Custom Forms 1
S Custom VBA forms in Outlook--how to call w/macro? Outlook VBA and Custom Forms 1
F Outlook 2016 call to Stop Timer Event Outlook VBA and Custom Forms 4
C Unchecking "Send immediately when connected" does not work on apps that call Outlook Using Outlook 1
K call a help file when click on a button xml ribbon Outlook VBA and Custom Forms 1
C OL Sub through or by Excel Macro Call Outlook VBA and Custom Forms 1
R Phone Call Start Date - Phone Log BCM (Business Contact Manager) 1
B Good Call Log Concept? Outlook VBA and Custom Forms 5
T exception when I call ActiveDocument.Range(0,0).Editors.Add(-1) Outlook VBA and Custom Forms 2
D Call add-in method from macro? Outlook VBA and Custom Forms 1
M Phone Log Reminder to call back BCM (Business Contact Manager) 1
R Help, Outlook2003 won't quit after call OnDisconnection? Outlook VBA and Custom Forms 3
C How do you call a exe and interact with the output interactively Outlook VBA and Custom Forms 2
