Wrapping and wrong encoding
Commodore
Outlook 2013 32 bit
I remember there used to be issues with text/paragraph wrapping in the past (but that was a really long time ago). However, I just discovered Outlook 2013 now wraps my plain text lines - a friend of mine complained the URL to an article I sent was broken. I don't remember these kinds of issues before, though.
I tried sending a lorem ipsum mail to myself, and the paragraph was indeed "neatly wrapped".
Also, these lines in the header bug me:
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
...because I am certain I set UTF-8 when I installed this Office as well as previous two versions.
Is this some sort of a bug?
Outlook wraps long lines in plain text messages you *receive* by removing extra line breaks. If a url is broken, it remains broken though. You can usually send long urls by wrapping them in greater and less than carets <url>.
When you send messages, it's controlled by line length setting is option and the message encoding.
You can try this edit and see if it changes things:
HKEY_CURRENT_USER\Software\Microsoft\Office\15.0\Common\MailSettings
DWORD: WrapLines
Value: 0
I don't think this value works in 2013 (have not tried it). You can try it and see what happens- Quotable-Printed encoding is what prevents line breaks in plain text. 1 is QP. (0 is autodetect, 2 is base64, 3 is 8bit)
HKEY_Current_User\Software\Microsoft\Office\15.0\Outlook\Options\Mail
DWORD: InternetMailTextEncoding
Value: 1
As an FYI, it looks like the first key (wraplines) should fix it for you. That converts plain text to QP - it worked here with a 207 character url.
Content-Type: text/plain; charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
M Stop ribbon item tool tip text from wrapping? Outlook VBA and Custom Forms 2
Q Text Wrapping in month view Using Outlook 7
M Something went wrong and your search couldn't be completed Using Outlook 1
L Correct E-Mail Pulling Wrong Mail Using Outlook 5
C Outlook Autocomplete suggestions showing wrong person's name against an email address Using Outlook 0
B Sharing Outlook calendars gone wrong Using Outlook 0
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
N Copies of emails from rules have wrong from: account Using Outlook 0
A Replies being sent from wrong account Using Outlook 8
W Sending To Wrong Account Using Outlook 15
Z Outlook for G Suite emails showing wrong dates Using Outlook 4
C How to avoid sending mail to the wrong contact person Using Outlook 1
Diane Poremsky Warn before sending messages to the wrong email address Using Outlook 1
M Messages in Outbox reminder is wrong Using Outlook 4
R Correct a wrong csv export file from WLM 2012 Using Outlook 0
R OL2010 - Send to Mail Recipient going to wrong account Using Outlook 1
B you are not responding to the latest message - wrong email Using Outlook 1
E Recurred tasks are created with a wrong due date Using Outlook 0
Diane Poremsky The calendar shows the wrong day at the beginning or end of the month Using Outlook 0
J Calendar search failing & wrong indexlocation showing..OL2010 Using Outlook 3
e_a_g_l_e_p_i Is something wrong with my themes Using Outlook 3
G Wrong display name in from column when removing pf replication Exchange Server Administration 1
MattC Some fonts the wrong size in incoming emails in Outlook 2007 Using Outlook 6
G Onding e-mail with wrong signature Using Outlook 0
O BCM Dbase Issues (both not seeing dbase & not allowing restore for wrong owner BCM (Business Contact Manager) 2
P Outlook 2013 rules -- not working reliably -- moving messages to wrong boxes Using Outlook 0
L Schedule Assistant shows wrong working hours Using Outlook 1
C Outlook 2003 displays wrong account in IMAP Using Outlook 5
G Outlook 2013 display the wrong font Using Outlook 7
S Wrong email account displayed in folders Using Outlook 3
J Incoming emails going to wrong sub-folder Using Outlook 4
T Change from exchange server to pop when I set up outlook wrong Exchange Server Administration 1
S Outlook 2003 - showing meeting on wrong day and time Using Outlook 1
G appointment times are wrong Using Outlook 3
V What is wrong with Outlook Connector - it still errors out on an EMPTY Hotmail Using Outlook.com accounts in Outlook 3
D Outlook sends e-mails using the wrong account Using Outlook 0
V Wrong Address List being used (or Resolved by ALT + K) Using Outlook 1
R How to configure outlook to avoid sending emails from the wrong account Using Outlook 24
V meeting displayed at wrong time Using Outlook 4
K Quick Print shows wrong date on Occurrences Using Outlook 1
K Business account window is wrong BCM (Business Contact Manager) 1
S Restrict method question on email. What am I doing wrong? Outlook VBA and Custom Forms 2
G wrong body .msg coding Outlook VBA and Custom Forms 6
L wrong icon displayed for outlook custom form Outlook VBA and Custom Forms 8
D Application.ActiveInspector().CurrentItem Returns Wrong(Old) Value Outlook VBA and Custom Forms 3
D Exporting reports to Excel gives wrong numbers BCM (Business Contact Manager) 1
D Wrong Form view in "Developer" Tab for "Accounts" BCM (Business Contact Manager) 4
