Social connector not working with LinkedIn?
I have been using the Social connector every since I bought Office 2013 and love the way you get updates for Facebook and LinkedIn underneath the message pane or underneath contacts.
However recently, I have noticed that I don't get any LinkedIn updates any more. I tested this by actually going to the web version of LinkedIn and seeing which of my contacts was actually doing stuff in LinkedIn, and then checking under the contact whether I could see the update. Alas no. Facebook working fine, but LinkedIn not.
I then noticed on the web that LinkedIn were starting to refuse API access to some third party tools, but it appears Microsoft is off the hook as they are still a preferred partner.
Looking for a solution I came across LinkedIn's page itself: https://www.linkedin.com/static?key=microsoft_outlook. This seems to install a social connector of its own, but I can't work out whether or not I should install it. In fact after trying the first time, it now permanently gives me an error.
So what should I do? Possibly completely remove the social connector and try re-installing? Is anyone else able to get LinkedIn updates under the contact pane?
Phil
I believe the connector at linkedin is for older versions of Outlook where the connector is installed by the user. In outlook 2013, everything is installed from you.
Did you try signing out of linked in and signing back in? In the Social connector options, click X to the right of linkedin to delete it, close the dialog and reopen, then sign back in.
witzker social connector 2010 does not show all emails to or from contact Using Outlook 0
iwshim Outlook Social Connector for Facebook - updates? work arounds? Using Outlook 1
Diane Poremsky Outlook's Social Connector Using Outlook 1
Diane Poremsky Goodbye, SharePoint Social Connector Using Outlook 0
Diane Poremsky Change the Social Connector Account Using Outlook 0
Diane Poremsky LinkedIn Social Connector Provider: Going Away Using Outlook 1
Mr Mayor Social Connector, Using Outlook 1
R Outlook 2013 and Social Connector Using Outlook 1
B Outlook Social Connector Using Outlook 1
kburrows Outlook 2013 - Removed Social Connector, LinkedIn and Messenger Reappear Using Outlook 7
K Social Connector Deployment Using Outlook 1
Diane Poremsky Facebook and Live Providers for Social Connector Using Outlook 2
Forum Admin Developing Social Connector Providers Using Outlook 1
Richer Fortin Control parameters in Social connectors Using Outlook 1
R Outlook 2013 People Pane - Where is the "Add" button for social networks? Using Outlook 4
V OSC for Other Social Networks Using Outlook 3
P Can data from Social Connectors be displayed in a Contact List View? Using Outlook 2
Diane Poremsky Outlook Connector Contact Sync Bug (Fixed) Using Outlook 0
Ascar_CT MS Outlook 2010 with Hotmail connector went spam control nuts Using Outlook.com accounts in Outlook 1
D Outlook 2010 contacts syncing intermittently via Outlook Connector Using Outlook.com accounts in Outlook 2
O Outlook 2013 using DAMO (connector for Domino) Sent Items Issue Using Outlook 2
D Outlook 2007 Repeatedly Requesting Password via Outlook Connector Using Outlook 1
E Zimbra Connector and Search Using Outlook 10
P Encoding problems after synchronization with Outlook Connector Using Outlook.com accounts in Outlook 6
T syncing email using Outlook Connector Using Outlook.com accounts in Outlook 16
S Receiving/accepting meeting invitation into new calendar (outlook connector) Using Outlook.com accounts in Outlook 0
M Microsoft Outlook Hotmail Connector Error: The text exceeds the limit of 1024 Using Outlook.com accounts in Outlook 1
B Outlook connector only works when set to default Using Outlook.com accounts in Outlook 5
B Having Recent Issues with Hotmail Connector? Using Outlook.com accounts in Outlook 17
P Multiple accounts and single Calendar file (Outlook 2010, using Connector) Using Outlook 1
S Outlook connector, numerous versions, connection issues Using Outlook.com accounts in Outlook 1
A Problems with connector. Error message 80041003 Using Outlook.com accounts in Outlook 7
A Need May 2011 14.2 Outlook Hotmail Connector. Using Outlook.com accounts in Outlook 1
I Duplicate contacts in iPhone resulting from LinkedIn connector in Exchange Using Outlook 3
R Outlook Connector wont sync with iPhone/iPad Using Outlook.com accounts in Outlook 1
D How to correct Outlook Connector Live ID Using Outlook.com accounts in Outlook 1
R Outlook Connector will not download ALL messages from hotmail accounts Using Outlook.com accounts in Outlook 4
J Outlook Connector equivalent for Google Mail? Using Outlook.com accounts in Outlook 2
V What is wrong with Outlook Connector - it still errors out on an EMPTY Hotmail Using Outlook.com accounts in Outlook 3
V Creating Distributions in Outlook Connector Using Outlook.com accounts in Outlook 1
S Connector Forces Outlook 2007 To Hang On Send/Receive Using Outlook.com accounts in Outlook 3
B Hotmail Connector messed up my Wifi Using Outlook.com accounts in Outlook 1
J Has Outlook Connector just lost all my folders?! Using Outlook.com accounts in Outlook 3
