Icloud/Outlook Syncing Issues
VCC
I just synced outlook with icloud for the first time and now my "desktop" outlook has been converted to an icloud version. It also shows old appointments, appts. multiple times and everything is very slow (not responding) to respond.
Is there a way for me to undo what I did and get it back to the desktop version I was using before please? Thank you
If you sign out of iCloud and choose the option to save a copy of the iCloud calendar and contacts, it will put everything into a folder or pst - then you can drag them from the backup folders to the default folder.
Have you rebooted at least once? If not, try rebooting and see if it behaves better.
V Outlook not syncing with iCloud Using Outlook 5
V Syncing Outlook installs with iCloud Using Outlook 1
B iCloud and Outlook only syncing in one direction Using Outlook 1
C Outlook local calendar & iCloud calendar syncing query Using Outlook 3
K Syncing outlook with iCloud question Using Outlook 5
E Outlook and iPad syncing, IMAP and iCloud Using Outlook 11
R Outlook syncing with iCloud Using Outlook 1
M Syncing using iCloud mangled my Outlook 2007 file Using Outlook 2
Diane Poremsky iCloud, Outlook 2016, and Windows 10 Using Outlook 0
Diane Poremsky Online Services in Outlook: Gmail, Yahoo, iCloud, AOL, GoDaddy Using Outlook 1
M Can't Delete iCloud Calendar Notifications From Outlook 2016 Using Outlook 0
Brendan Keeping Outlook contacts on PC after signing out of icloud Using Outlook 1
David Langer iCloud 5.0 for Windows and Outlook 2016 Using Outlook 5
S Using iCLoud Contacts for Outlook Email Using Outlook 1
230Grains iCloud COM Module Keeps de-selecting in Outlook 2013 Using Outlook 1
I iCloud Calendar and Contacts in Outlook 365 Using Outlook.com accounts in Outlook 2
K Outlook ICloud Data Folder Using Outlook 2
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
M Outlook & Icloud Using Outlook.com accounts in Outlook 2
R Moving contacts from ICloud back to Outlook 2010 Using Outlook 4
R Disappearing data from outlook calendar after using icloud-ical Using Outlook 2
yooper46 Removal of iCloud contacts in Outlook contact list Using Outlook 8
