How to block time in another calendar without invite?
igrokit
I have two exchange accounts, both in the same outlook 2013 profile. I show both calendars in my calendar view. One is for work and one is private.
What I want is that if I make an entry in my private calendar, the same time is blocked automatically in my work calendar (if possible with same attributes like out of office, busy, tentative, free). However, I do not want to invite my work identify to all my private entries. I know I can show both calendars side by side or even overlay, but that would not help me.
Let's say I have a private meeting from 10 to 12 with Peter, I want to send the meeting invite to Peter from my private identity/account only. At the same time, the time 10 to 12 should be blocked in my work calendar, since I do not want that my work colleauges send me an invite for say 11 to 12. They should see that I am already blocked.
On the other hand, entries in my work calendar do not have to block time in my private calendar.
Is there a way to do that without having to invite my work identity for each of my private calendar entries?
Dan
igrokit
Thanks a lot, Diane.
Looks like the macro would do what I was looking for. quite some discussions on the code samples. Hopefully I am able to extract what I need
As it was said by some commenters there, I am also not quite a geek with macros. But I will try.
Dan
I Exchange 2019 - MICROSOFT-CORP-MSN-AS-BLOCK Exchange Server Administration 0
L Block email signature image Using Outlook 1
Diane Poremsky Block Macros in Office 2013/2016 Using Outlook 0
A Block user to send emails to specific set of email ids Using Outlook 1
O Block outlook appoinments Using Outlook 1
R How to Block from sending mail to public domain. Using Outlook 8
H In Exchange 2010, how to block an email containing an attachment that has foreign characters Exchange Server Administration 1
Wotme VBA to block senders Outlook VBA and Custom Forms 1
A 5.7.1 Recipient not authorized, your IP has been found on a block list Using Outlook 1
S Block read receipt when outlook is configured to Exchange server Using Outlook 0
M Change font of from/to/subject block Using Outlook 1
O Block sender option disappeared? Using Outlook 3
L Block others from inserting appointments in your calendar Using Outlook 3
M block emails with specific subjects BCM (Business Contact Manager) 1
X Highlight block of text in an outlook mail using c#2008 vsto Outlook VBA and Custom Forms 1
Q Otlk 2007 does not block when in "always prompt for..." mode Outlook VBA and Custom Forms 2
R Clear one category when another is chosen Outlook VBA and Custom Forms 1
N Item cannot be saved because it was modified by another user or window, and, Item could not be moved... Using Outlook 0
e_a_g_l_e_p_i Is it possible to transfer things from one calendar to another Using Outlook 2
S Email Generated from another program and then edited sends original email. Using Outlook 2
R Time for another article on contact cards? Using Outlook 0
M Moving mail to another folder is much slower than before (Office365) Using Outlook 0
B Moving account, contacts & emails to another H/D with MSOutlook Using Outlook 5
M Shortcut to another outlook item Using Outlook 0
M FW Email via Outlook and another requirement Outlook VBA and Custom Forms 1
Diane Poremsky Set Another Data File as Default When Using an Exchange Account Using Outlook 0
D Unable to Send On Behalf of Another User Exchange Server Administration 0
D EXPORTING MS EXCHANGE EMAILS to another platform Exchange Server Administration 10
mrmmickle1 UserProperties VBA to move message to another folder Outlook VBA and Custom Forms 7
P Office 365 manage another person's calendar Using Outlook 0
TheDavidSlight Daylight savings - another subtle bug ... Using Outlook 3
