shortcut to more stationery
Quentin
Is there a way to create a shortcut to "more stationery" in the ribbon or quick access toolbar? We've created several html stationeries, and would like a quicker way to them other than "New Items / E-mail Message using / more stationery."
Possible?
Using Outlook 2010/2013.
More Stationery is under Commands not in the ribbon under Quick Access Toolbar, should be in customize ribbon too (but I didn't look).
I think i have a macro here somewhere for inserting html stationery - I'll see if i can find it.
Here's a macro that can do it - however - any images in the html code need to use the full file path, not just the image name.
oops. My bad. I forgot to paste in the link to it. :) I did two articles the other day - how to use vba to open a new message with selected stationery and how to apply stationery to a reply or forward. The only drawback (that I have discovered) is that background images need to use the full path to the image, which is not the case with the default stationery. You can edit it in notepads to fix it though - then resave (may need to give your account file permissions to save in the default location.)
http://www.slipstick.com/outlook/email/create-new-message-using-html-file-stationery/
S Outlook 2016 A Shortcut to recall and delete and sent message. Using Outlook 1
M Shortcut to another outlook item Using Outlook 0
R Shortcut for attaching the same file repeatedly Using Outlook 6
M Contact group shortcut Using Outlook 3
S Shortcut/button to a Calendar Group Using Outlook 0
B Can't create shortcut to Quickparts Using Outlook 3
iwshim word shortcut to search outlook Using Outlook 3
O Address Book Shortcut Using Outlook 4
S Desktop shortcut Using Outlook 1
A Shortcut for sending complete mail Using Outlook 1
I jump to body in open message with one keyboard shortcut? Using Outlook 3
T Column Header Keyboard Shortcut Available? Using Outlook 5
D Selection of Send-From Account with Template VBA Shortcut Using Outlook 0
W keyboard shortcut to open Outlook... ? Using Outlook 2
S OL 2010 shortcut to edit received mail Using Outlook 3
L Shortcut to specific contact Using Outlook 4
C Want to Create Shortcut to Open Specific Calendars at the Same Time Using Outlook 2
T Is it possible to INSERT a string into email body via Shortcut. Outlook VBA and Custom Forms 2
C blocking two or more word domains separated by period/dot Using Outlook 3
O Display more months in 'Tasks' Using Outlook 3
E When more than "ItemSend" is needed Using Outlook 5
Diane Poremsky Booking meetings more than 180 days out Using Outlook 1
Diane Poremsky Could not complete the operation. One or more parameter values are not valid. Using Outlook 0
W Showing more months in the Calendar nav pane Using Outlook 10
B Search Folder for search messages in more than one account and / or multiple PST folders Using Outlook 3
C Quick Parts signatures suddenly require more letters Using Outlook 2
Diane Poremsky Make 'today' stand out more in the calendar Using Outlook 0
Diane Poremsky More Tools and Utilities for Sharing Outlook Data Using Outlook 0
N To do bar - show more than 30 days of appointments Using Outlook 0
F Missing "More Settings" in Outlook 2007 Professional Using Outlook 8
O Stop more than one person responding to an email? Using Outlook 1
J Show three or more months in Calendar Using Outlook 1
M Can't open same msg file more than once at the same time in Outlook 2010 Using Outlook 7
A Setting RULES with more than one condition in MS OUTLOOK Using Outlook 6
