Outlook Contacts Help
Expressman
Hi Guys,
We using Outlook 2010 at work. For some reason if you edit a group contact, adding new contacts to the group, and save + close the group, it does not save the contacts you added to the group. You need to delete the group entirely and then re-create it from scratch adding the extra users and then save it. But just editing it does not work.
If you delete users, it save the change of deleted users. But just does not want to save added users.
How do I fix this?
The group itself is not updated or when sending email to the group, the new members/changed members aren't updated?
The second issue - updating a group but email goes to the old version is a known issue, caused by the autocomplete cache. The autocomplete cache remembers the old version of the group. Delete the group name when it comes up in the to field and retype it or select it.
X business owner in dire need of help outlook is not syncin my contacts! Using Outlook.com accounts in Outlook 2
W Migrating Outlook 365 Contacts & Calendar Using Outlook 2
R How to delete Facebook Contacts folder in Outlook 365 Using Outlook 7
C Import Outlook 2016 contacts into to: field Using Outlook 1
S Outlook.com birthdays show up 1 day late on iPhone contacts list Using Outlook.com accounts in Outlook 27
S Outlook.com cannot edit some contacts Using Outlook.com accounts in Outlook 5
S Missing Outlook calendar and contacts Using Outlook 0
Cdub27 Move Outlook 2016 Contacts to Other Folders - Extremely Slow !! Using Outlook 6
A add birthday to outlook contacts Using Outlook 1
O :Managing contacts in Outlook 2016 Using Outlook 0
E 365 Outlook changed from POP3 to IMAP,all contacts lost Using Outlook 3
S Outlook VBA Contacts Notes Outlook VBA and Custom Forms 0
O Contacts folders, outlook 2016 Using Outlook 0
C Outlook 2016 doesn't show contacts in address book Using Outlook 2
Diane Poremsky Batch Import Photos into Outlook Contacts Using Outlook 0
GregS No contacts sync from Outlook 2016 to Windows Phone Using Outlook 0
GregS Sync contacts Outlook.com to "MS People" mobile Using Outlook 1
T Uploading Outlook 2016 Contacts to Exchange Server Drops "Company" field data in 30% of records Exchange Server Administration 4
Diane Poremsky Sharing Outlook Calendar and Contacts Using Outlook 0
Diane Poremsky Setting the default Country for Outlook Contacts Using Outlook 0
J Outlook Contacts - Design This Form Outlook VBA and Custom Forms 2
L Synching Office 365 contacts to Iphone MS Outlook client Using Outlook 5
Diane Poremsky Add to Outlook Contacts Bug (Fixed) Using Outlook 1
