reminder for every 15 working days
araamuthan
Hi All,
In my project we are running the project specific task for every 15 working days once.
So I need to set the reminder for every 15 working days.
I have tried the same scenario in outlook but no luck
Can anyone help me
Thanks and regards,
Araamuthan
Sorry, outlook doesn't support anything like that - however if the task is being regenerated daily instead of lasting 15 days, it will regenerate a reminder when you mark the daily task complete or you could use one task due in 15 days and set the reminder for the 15th day and snooze it for 1 day.
That uses a spreadsheet to create the list and import because Excel supports working days (M-F). I would start by exporting Tasks to Excel to get the field names. Delete the data and any columns you won't be using.
Then in the Start field, add the first date in then below it put the formula and drag down to fill - changing A to the correct column.
=WORKDAY(A2,15)
if you want to consider holidays, create a list of holiday dates at the end of the field names and reference them in the formula:
=WORKDAY(A2,4,F2:F147)
Fill in the fields and import.
araamuthan
Hi Diane Poremsky,
Thanks for the reply it was really helpful.
Still I am facing some issues in that.
I have attcahed my Excel Calendar, Outlook calendar in this post plase take a look at that.
I have used the below fields in my Excel calendar
Subject
StartDate
StartTime
EndDate
EndTime
Alldayevent
Reminderonoff
ReminderDate
ReminderTime
RequiredAttendees
and I have successfully mapped these to the corresponding outlook fields. You can see these filelds in the attachment.
I have given the StartDate as 4/17/2015 (Monday) and EndDate as 4/17/2015 then in the second cell I used the formula
Workday(B2,2). Ideally it should block the calenar for every 2 working day but in Outlook calendar it only blocks on 4/17/2015. I cant see the event for the next second working day i.e 4/21/2015 (tuesday), 4/23/2015 (thursday) and so on. It seems the Outlook was not taking the formula.
One more thing when I double click on the event I cant see the attendees but I have used the field "RequiredAttendees"
And I need to set the reminder one day before the event.
Please help me in this.
araamuthan
I forget to mention the below detail:
Subject of my event is "# Audit Management Job" in the attachment I have highlighted with the rectangular box.
Please let me know if you need more information on this.
Thanks and regards,
Araamuthan
What formula did you use for the dates?
You are using column B so the formula would be =WORKDAY(B2,15)
The reminder date can be =B2-2, starting with the first row of data and filled down the entire column, or since you want to use workdays, =WORKDAY(B2,-2)
I think if you leave the end date field blank, it uses the same date as the start date - or you can use =B3 to grab the start date.
araamuthan
Hi Diane Poremsky,
Thanks for the reply.
Initially I was using the formula WORKDAY(B2,15) . It was not setting the reminder.
Now I am using WORKDAY.INTL(B2,15) which is working fine for me.
As per your suggestion I have removed the EndDate, it seems fine now.
Now I am facing problem in attendies.
I have used the filed called "RequiredAttendees" and I mapped the same to Outlook field but which is setting reminder only for me. I can see the events in my calendar not in my colleague.
I have attached the screen-shot of Excel calendar, reminder, outlook calendar.
Thanks and regards,
Araamuthan
Don't know why workday didn't work, but workday.intl is better - you can control the non-working days using it.
While you can set attendees, they aren't actually sent to the attendees - you'll need to open and send.
araamuthan
Hi Diane Poremsky,
Thanks a lot for your help, I have set the reminder successfully.
Regards,
Araamuthan
araamuthan
Hi Diane Poremsky,
I am facing issue in setting reminder.
My requirement is to set the rminder one day before the event.
Event occurs every 15 working day. As per your suggestions I have used WORKDAY(B2,15,G2:G8) formula for Start Date filed which is woking fine.
For the reminder I have used WORKDAY.INTL(B2,-1) in Reminder Date where am facing problem.
Note:I have successfully Reminder Dtae field to the corresponding outlook field.
I have imported the Excel with all these details in Outlook, which actually blocking the calender only for event date not for the reminder date.
I am getting the pop-up reminder only for the reminder date but i need the reminder one day before the event.
Please help me out in this.
Please find the attachments.
Please let me know if you need more information.
Thanks and regards,
Araamuthan
appointments use the remindbeforehand field and the reminder field needs to be set to 1.
G Arggh, weakness of reminder for every Task recurrence Using Outlook 0
D Updating a recurring meeting cuses a reminder to be sent for every occurence. Using Outlook 2
A Reminder duplication Outlook and Outlook.com Using Outlook.com accounts in Outlook 5
V Accepted meetings do not get the default reminder Using Outlook 0
S Command Button_Click action on Item/Reminder Outlook VBA and Custom Forms 3
F how do i set a reminder in onenote 2010 Using Outlook 8
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
A End-time meeting reminder (or "negative" time relative to the meeting start time) Using Outlook 1
M VBA to send reminder email if no response Using Outlook 13
B Change font of reminder of an email header Outlook VBA and Custom Forms 3
O Reminder due end of August is showing up now Using Outlook 2
L Calender reminder emails Using Outlook 3
S Reminder Dialog Open Button Using Outlook 2
F Set (flagged) reminder for next business day Using Outlook 4
H send reminder if no reply received on first or original email using macro Using Outlook 2
Diane Poremsky Open a Webpage When a Task Reminder Fires Using Outlook 0
L Fake reminder apperaring (not in calendar) - how to remove? Using Outlook 5
M Messages in Outbox reminder is wrong Using Outlook 4
M Send an Email When a Reminder Fires Outlook VBA and Custom Forms 1
E Send a Reminder/Task to certain Email Recipient Using Outlook 5
Diane Poremsky Send an Email When a Reminder Fires Using Outlook 0
Diane Poremsky Setting Custom Reminder Times Using Outlook 0
Diane Poremsky Receive a Reminder When a Message Doesn't Arrive? Using Outlook 10
F e-mail reminder for shared calendar Outlook VBA and Custom Forms 1
K VBA - Prompt for reminder date time Outlook VBA and Custom Forms 7
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
rc4524 Create auto follow-up reminder email for already sent messages Outlook VBA and Custom Forms 1
smokiibear Share Office 365 Tasks such that Other Users also Are Alerted with Reminder Using Outlook 1
J Change reminder times of future appointments Using Outlook 1
S PoP up reminder while opening the outlook? Outlook VBA and Custom Forms 1
S Pop up reminder while i close outlook Outlook VBA and Custom Forms 5
H Create a Task by Draft-EMail > Task+Reminder not Working Outlook VBA and Custom Forms 1
D Outlook 2007- old reminder popups Exchange Server Administration 4
2 Email not replied to reminder - aka boomerang? Using Outlook 3
R Problem with Reminder appearing in Inbox Using Outlook 5
J Reply All and No attachment Reminder Using Outlook 14
L Auto-set followup/reminder popup box for ALL sent emails. Using Outlook 0
