What code to use to move the custom field values to message body when sending e-mail ?
Outlook 2013 32 bit
I quite new to vba and i appreciate if you could help me whit a code that moves the custom filed title and values of an outlook custom form into the message body when sending the custom form message( sending the e-mail) , so the recipient will see it in the message body.
Michael Bauer
I doubt there exist a macro for that. If you want to write/learn it: See the ItemSend event, which is triggered when you hit the Send button. All custom fields are available in the UserProperties collection of the item. This would write a value of a certain field into the message body (in the ItemSend event):
Item.Body=Item.UserProperties("xxx").Value
Outlook 2013 32 bit
Thank`s.
Outlook 2013 32 bit
Can you please show more exactly where to put the code ? It will write the name of the field to or just the value ?
Outlook 2013 32 bit
To write the standard fields value in body message help me to correct the code :
Function Item_Send()
Item.Body = Item.Body & vbCrLf & Item.UserProperties("textbox")
Item.Body = Item.UserProperties.Item(strField)
End Function
This will write the name of the fields to ?
Michael Bauer
The Item_Send function is called differently and needs more setup. I'd recommend using the ItemSend function of the Application object.
As to the name of the field, your variable strField contains it.
Outlook 2013 32 bit
It`s not working ...Please guide me more , below is what i did :
Aussie Outlook 365 Rule runs manually but returns the error code "an unexpected error has occurred" when incoming mail arrives Using Outlook 0
Alex Cotton "invalid or unqualified reference" on code that should work Outlook VBA and Custom Forms 5
D Command Button code will not execute. Any suggestions Please. Outlook VBA and Custom Forms 2
C Color Code New Calendar Items Using Outlook 2
S my vbscript button1_click code works on appointment created but not on opening an existing apntmn Outlook VBA and Custom Forms 16
M regarding the Create Contacts From Messages code Using Outlook 8
D VBA Code to strip Subject Line when replying or forwarding Using Outlook 3
L Outlook 2007 Contact Form Code Not Working Using Outlook 20
A Check for attachment code not working Outlook VBA and Custom Forms 1
A Code to automatically delete message after sending Outlook VBA and Custom Forms 6
G Annoying page of code when receiving Using Outlook 14
Z Default VBA code for extracting data from email (Outlook) to Excel? Outlook VBA and Custom Forms 1
