Must now "View on Facebook" for Mentions/Comments-Outlook 2013 click-to-run
DKW
For the past 2 months, when someone "Mentions" me on Facebook, I can no longer see the content within the email notification, I must click the "View on Facebook" box to go see it.
Also, on some Facebook "comments", you can actually see part of the comment in the notification's header, but NONE in the body of the notification, you must click "View on Facebook" to go see the comment, as well.
Now, are these Facebook "Notification" changes, or Outlook 2013 "click-to-run" changes??
This seems like further efforts on Facebook's part, to force one to go to the site.
C must select message to trigger safe list Using Outlook 3
wallisellener BCM must be activated BCM (Business Contact Manager) 2
T In Outlook 2013, must downloaded pictures in an email always be retained? Using Outlook 8
R The action cannot be completed. The connection to Microsoft Exchange is unavailable. outlook must be Using Outlook 1
P Messages stuck in outbox and must be sent again. Using Outlook 1
T You must Provide a value for this property on powershell cmdlet Exchange Server Administration 3
S Must accept EULA everytime Outlook 2003 opens in Windows 7 Using Outlook 3
J Split reading view with history Using Outlook 2
P Calendar Day View only shows 1 all day event Using Outlook 0
J Weekend View in Calendar Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
K Accentuating today in Outlook calendar month view Using Outlook 2
T How can we view Blocked email addresses Using Outlook 6
P How can I change my calendar view back Using Outlook 3
N Column view fonts Using Outlook 4
copperberry How to view all tasks across task folders Using Outlook 3
A Day view - print appointment details Using Outlook 1
J Outlook 2016 shows Meeting Organizer in Calendar View Using Outlook 5
B outlook view control Outlook VBA and Custom Forms 0
avant-guvnor Unable to view certain emails in Outlook 2016 Using Outlook 16
