RSS export as OPML problem
eapie
Outlook 2013 32 bit
I am collecting RSS feeds and want to export them to an OPML file but entries are missing.
I get an OPML file by file/ .../ Export RSS Feeds to an OPML file. The OPML I get is below:
<?xml version="1.0"?>
<opml version="1.0">
<head>
<title>OPML exported from Outlook</title>
<dateCreated>Mon, 3 Aug 2015 21:53:12 +0100</dateCreated>
<dateModified>Mon, 3 Aug 2015 21:53:12 +0100</dateModified>
</head>
<body>
<outline text="Election 2015" type="rss"
xmlUrl="http://www.telegraph.co.uk/news/general-election-2015/rss"/>
</body>
</opml>
But when i look at the link in explorer it only shows 200 entries but the RSS folder the export was taken from had over 700. Why do I not see all of them? I can;t find how to get rid of this limit.
Also, when importing the OPML file into outlook I oddly only got 20 returned entries.
Any ideas as to why this is happening please, I am completely stuck!
thanks so much!
Are you talking about 700 separate feeds or 700 rss items?
No, i have no idea why it's not importing the feeds - unless you have the other feeds already in outlook or the opml is corrupt.
eapie
Outlook 2013 32 bit
Hi, thanks for replying. There are 700 RSS items in one RSS folder. What I'm trying to do is get all those RSS items in a file so that I can iterate through them in a program. I need the contents of the item and the date/time.
I've repeated creating the OPML and then opening the url in internet explorer and it only shows me 200 RSS items. I am thinking there is an export or viewing limit somewhere but i can't find it.
Any ideas?
thanks again
The opml doesn't have the items - it has the feeds you are subscribed to. if you need the contents of the folder you can use VBA or if the information you need is visible in fields you can add to the view, you can use table view, copy and paste.
I use a macro to save rss messages in a folder to one text file. it's at http://www.slipstick.com/developer/code-samples/save-email-message-text-file/ - under Save selected messages to a single text file. you'll probably want to delete the write sender and write recipients lines.
eapie
Outlook 2013 32 bit
Ah I understand now. Thanks very much for the explanation and link to the macro :)
S Receiving duplicate messages from RSS feeds Using Outlook 3
Diane Poremsky How to Change the Font used for Outlook's RSS Feeds Using Outlook 0
Diane Poremsky How to Remove RSS Support from Outlook Using Outlook 0
norbertlars Outlook 2016 - rss Using Outlook 3
N Going Forward: Using Outlook 2016 for RSS Feeds Using Outlook 2
O How to delete duplicate RSS messages? Using Outlook 6
Horsepower Duplicate RSS feeds Using Outlook 5
Flavia Lovell Can Not Subscribing the RSS Feed of Elance Jobs Using Outlook 3
Commodore Repeated RSS items downloads Using Outlook 1
V Exporting RSS Feed to OPML file Using Outlook 8
Jennifer Murphy Sync RSS feed message after Safe Mode Using Outlook 3
J RSS feeds don't get any messages Using Outlook 4
Commodore Deleting folders or feeds when deleting from default RSS Feeds structure? Using Outlook 7
Commodore Importing RSS on another computer (and feed locations) Using Outlook 8
Commodore Why some RSS feeds stop getting updates? Using Outlook 12
Commodore Outlook 2007 not closing network connections with RSS feeds Using Outlook 1
billzant RSS feeds and google Using Outlook 2
F Outlook Re-Downloading RSS Feed Posts Days Later Using Outlook 3
IGWright Outlook 2010 RSS Feed Folder Issue Using Outlook.com accounts in Outlook 6
T Permanent Removal of RSS feeds folder amd Search folder in Outlook 2010 Using Outlook 10
Commodore RSS feeds from sites that require login Using Outlook 5
A RSS feed inbox "new item event"? Outlook VBA and Custom Forms 6
D MailItem from an RSS feed Outlook VBA and Custom Forms 2
B How to add RSS feeds for Microsoft Newsgroups Outlook VBA and Custom Forms 3
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 3
K Export Folder to PST Outlook VBA and Custom Forms 2
O Export Outlook calendar appointments by filters and date range Outlook VBA and Custom Forms 1
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
J Export Zimbra to Outlook PST Using Outlook.com accounts in Outlook 1
S How to export urls from email to excel and check the status of the url ? Using Outlook 5
C How to export Outlook data to csv? Using Outlook 0
T How to Export mailbox from Outlook 2019 to MBOX format? Using Outlook 1
R How To Repair OST File & Export OST File to Outlook PST ? Using Outlook 3
avant-guvnor Export Calendar, Birthdays and Holidays Outlook VBA and Custom Forms 0
Diane Poremsky Export (Save) Outlook Contact photos Using Outlook 0
A How to export one email data to excel Using Outlook 1
W macro to export outlook emails to excel Outlook VBA and Custom Forms 6
E Exchanger service export detection Exchange Server Administration 1
