Emailing attachment from Word/Excel sends attachment but no message body
Mark Foley
Two workstations both have Office 2013 and both have this 100% repeatable problem. When in Word or Excel and selecting File > Share > Email > Send as Attachment; after composing the message and sending, the recipient does get the attachment, but none of the composed body text.
How do I fix this?
L Deleting Office 365 calendar appt w/o emailing invitees Using Outlook 3
B Can't run macro from QAT when emailing from Acrobat Outlook VBA and Custom Forms 0
B Losing Excel Data when emailing with OutLook 2010 Using Outlook 4
W Mass emailing to contacts linked to accounts BCM (Business Contact Manager) 1
M emailing all preivously contacted people Using Outlook 2
A Emailing Calendars Created in Outlook Calendar Printing Assistant Using Outlook 3
A Need help in creating a mass emailing plugin Outlook VBA and Custom Forms 1
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 3
Timmon Remove just one attachment before AutoForward Outlook VBA and Custom Forms 0
P File Picker for attachment Outlook VBA and Custom Forms 0
D Forwarding email based on the attachment file type and specific text found on the attachment file name Outlook VBA and Custom Forms 1
N File Picker for attachment Outlook VBA and Custom Forms 2
M Autoforward just attachment OR just body. Outlook VBA and Custom Forms 0
S save attachment with date & time mentioned inside the file Outlook VBA and Custom Forms 0
B Outlook 2010 Opening Mail Attachment Using Outlook 2
A Warning When Opening attachment Using Outlook 7
R Limiting length of saved attachment in VBA Outlook VBA and Custom Forms 2
P Outlook 2013 Word Share doc as Email Attachment now brings up Eudora. Using Outlook 1
geofferyh How to change the Attachment File Name? Outlook VBA and Custom Forms 1
D Autosave Attachment and Rename Outlook VBA and Custom Forms 1
N Macro for attachment saved and combine Outlook VBA and Custom Forms 1
Andrew Quirl Open attachment, manipulate without add-on program? Outlook VBA and Custom Forms 5
Commodore Attachment icon when there is no attachment Using Outlook 3
V Saving attachment from outlook in My Documents Outlook VBA and Custom Forms 14
N automatic response with an attachment based on the subject line Outlook VBA and Custom Forms 1
M Search for attachment filename Using Outlook 0
E Open olNoteItem Attachment Outlook VBA and Custom Forms 6
Vijay Reply all by attachment name Using Outlook 10
Michael R Belleville Making an Attachment Name the Message Subject Using Outlook 2
