invites from outside company arrives as regular mails
Karsten V
Outlook 2013 32 bit
Exchange Server 2013
First a little info on our setup:
Exchange 2013 CU8
Outlook 2013 full client 32 bit
Windows 7 64 bit Roaming profile
Problem:
When users reviews invites from the outside of the company they in some cases arrive as regular mail, internally when we send invites to meetings they functions as they are supposed to.
Regards Karsten V
Are all outside invites affected? That generally means the sender's server stripped the TNEF data that is normally included in the invites. The sender should have outlook set to always use iCalendar format for internet addresses. (Options > Calendar)
It's also possible the an antivirus scanner removed the TNEF data - either on your end or the sender's - using ical format for internet addresses will solve it.
http://www.slipstick.com/exchange/cmdlets/blocking-tnef-exchange-server/ shows how to check it on the server (the sender's, not yours). If they use Office 365 Exchange, it has no tnef to the internet enabled by default.
Karsten V
Outlook 2013 32 bit
Thanks for the answer.
No not all are affected, but it think the answer you gave me is the right one, ill get back on the ASAP, If you should know the GPO to set that for all users in my own organisation that will help us a lot, but set it on the Exchange would be even better.
Fozzie Bear Accepted Zoom Invites deleting without going into Default Calendar - Office 2016 Mac Using Outlook 4
A calendar invites sent from Microsoft Outlook to Mac Outlook is not working Using Outlook 2
T Move calendar invites to new calendar Using Outlook 5
A Multiple Outlook Invites Received by One Person Using Outlook 4
E Outlook 2013 is stripping out categories on sent meeting invites Using Outlook 0
D Meeting Invites Arrive as .ics Attachments Using Outlook 0
derek calendar invites not working anymore Using Outlook 7
T populating multiple calendars without invites Using Outlook 1
D Undeliverable message reply to invites Exchange Server Administration 2
J Meeting Invites Go Blank When Forwarding or Accepting Using Outlook 2
Q Disabling cancelled messages in meeting invites Using Outlook 1
P Change the Outlook.com "from" address for calendar event invites Using Outlook 9
A Outlook 2011 forwards calendar invites using "send as" not "on behalf of" ... Using Outlook 4
M Incoming invites to my imap account does not sync to outlook.com Using Outlook.com accounts in Outlook 29
M Outlook 2013 EAS, 3 imap accounts. Meeting invites not synced to outlook.com Using Outlook.com accounts in Outlook 1
S Modify recurring outlook invites based on form entry Using Outlook 0
A Stopping the required attendee invites Using Outlook 1
J Outlook Invites automatically adding 'Required Attendees' Using Outlook 1
B cant accept iCal calendar invites in Outlook 2007 (SP3) Using Outlook 4
B Meeting Invites not behaving properly Using Outlook 1
M Using Rules to forward calendar invites without attachments Using Outlook 1
N Outlook 2007 - Permissions for Meeting invites? Using Outlook 1
A Application_ItemSend not accessed when sending email outside outlook (i.e. word or send to mail from Using Outlook 7
S Outlook Macro for checking the mail is sent to outside organization Using Outlook 3
M Outlook Appointment item does not show the item outside the date range Using Outlook 2
R Rules and Alerts not sending emails to "outside Network" emails Using Outlook 1
P Addin / macro / rule to highlight email addresses outside company in To: field Using Outlook 3
R Outlook 2010 not sending to outside emails Using Outlook 1
N Archiving folders outside of Outlook to reduce PST file size Using Outlook 2
D Outlook AddIn can't load outside Visual Studio Outlook VBA and Custom Forms 1
O Address list - company and non-company ? Using Outlook 0
T One Contact list, two sections of company (none) Using Outlook 2
Scorpion New Contacts keep coming up as company Using Outlook 1
Derek Howell Company wide calendar Exchange Server Administration 1
J Outlook 2013 when clicking To in a new email show Company names Using Outlook 0
T Uploading Outlook 2016 Contacts to Exchange Server Drops "Company" field data in 30% of records Exchange Server Administration 4
J Subject Field is displaying Name and company Outlook VBA and Custom Forms 1
Diane Poremsky Update Contacts with a New Company Name and Email Address Using Outlook 0
J Create an appointment from Contact list with the Company name in the Subject line Using Outlook 1
A Create a Company Calendar Using Outlook 1
S rule, automatic replies, restricting them to within the company Using Outlook 1
B Full name of contact is now the company name Using Outlook 0
S How to set Company as default "File As" in Contacts for Outlook 2010 ? Using Outlook 1
