Resizing issue for message field
DS Lloyd
I am using Outlook 2007, and experiencing a problem with the Message field on a custom form. Although the form looks fine when opened by others at the same screen resolution as mine (1280 x 1024), if a user has set a low screen resolution (such as 800 x 600), then the the message field shrinks to a line or even to a point where no data entry is possible.
All other fields on the form remain OK and do not resize (I have not set the 'resize with form' option in any of the fields). It appears that the Message field is resizing although this option is not selected. I also note that the field appears to be unusual in that its advanced properties are much reduced compared to other fields on the form, such as there being no option to set Autosize to false.
The only work around I have found is to design the form at the lowest resolution, and then tick the 'resize with form' option. In doing this the message box is a reasonable size for those using low screen resolutions, but grows disproportionately as the screen resolution increases, so its not an ideal fix for all users.
Do you have any suggestions as to either stop the Message field from resizing as screen resolutions change (the best option), or to put a maximum height restriction on the field so that with my fix it does not become unwieldy at higher resolutions .
S Picture/Image/Attachment Resizing Outlook VBA and Custom Forms 5
F Resizing arrows unavailable only in Outlook Using Outlook 3
E After resizing Custom Task Pane "BeforeFolderSwitch" Event handler stopps being called Outlook VBA and Custom Forms 11
A Clipboard Resize Issue Using Outlook 7
D hide messege issue Using Outlook 1
B Outllok 2007 License Expired issue Using Outlook 0
M Calendar Time Zone issue Using Outlook 0
B My outlook calendar edit issue Outlook VBA and Custom Forms 0
D Unusual calendar issue Exchange Server Administration 0
D Multiple Accounts Issue Receiving Emails in 2016 Using Outlook 0
B Winmail.dat Issue Using Outlook.com accounts in Outlook 0
tswatek Issue with where Outlook saves new contacts Using Outlook 3
K Outlook with MDaemon Connectivity Issue Using Outlook 4
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
P Outlook hanging issue Using Outlook 0
K Outlook 2013 calendar issue with Outlook.com Using Outlook.com accounts in Outlook 2
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
K Insert screenshots issue Using Outlook 2
B Sub Calendar-Color Coding Issue Using Outlook 4
T Using Outlook 2007 with Comcast (.pst inbox issue) Using Outlook 1
Brendan.Z Outlook 2013 signature editing issue Using Outlook 3
F Custom contact form icon issue Using Outlook 1
A Autocomplete issue Using Outlook 6
wallisellener Synch issue BCM (Business Contact Manager) 2
H Outlook 2013 size issue Using Outlook 1
C Voting Issue with Shared Inbox Using Outlook 1
J Outlook 2013 Forms Issue Using Outlook 1
A How are you handling Outlook.com category issue and syncing Using Outlook.com accounts in Outlook 2
J Outlook.com EAS Issue Using Outlook.com accounts in Outlook 6
santheocles Issue in Outlook 2013 - cannot reschedule single task Using Outlook 0
P Outlook ruler issue Using Outlook 3
K Different kind of issue related to creation of archive after one has been deleted Exchange Server Administration 1
JR Ryan Outlook marks all as "Read" issue Exchange Server Administration 2
SirFishAlot SIGNATURE EMBED ISSUE OUTLOOK 2013 BCM (Business Contact Manager) 10
