Add attachments to appointment based on field values
alegatzke
Outlook 2013 64 bit
I'm working on a custom outlook form based on outlooks Appointment form.
The user will fill out the appointment as you would normally, and then there is a second page where you enter various details.
I have a few fields where an exact file path is stored. I want the document located at this path to be attached to the appointment request. In other words, the user will paste the file path into this field, and the file should be attached when the appointment invite is sent.
Is there any way to do this?
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge Using Outlook 0
Diane Poremsky Add attachments and set email fields during a mail merge to email Using Outlook 0
J Add Multiple Attachments Sources using VBA in Word Outlook VBA and Custom Forms 6
witzker Outlook 2019 Pls. add a Prefix for OUTLOOK 2019 here Using Outlook 1
L Macro to add Date & Time etc to "drag to save" e-mails Outlook VBA and Custom Forms 8
B Task Filter Not Working When I add too many criteria Using Outlook 0
