Winmail.dat Issue
BillK120
Outlook.com (as MS Exchange)
I am having the dreaded winmail.dat problem. I have an Outlook.com (new 365) email account set up as an Exchange account on Outlook 2010. It has been working great up to a couple of weeks ago. Nothing has been changed on my PC as far as Outlook is concerned. I am at a loss. I have tried everything listed here...clearing the autocomplete cache...the TNEF registry thing...the settings for sending messages...checking the contacts for RTF...I have tried EVERYTHING to fix it.
After much trail and error I was able to determine what was causing (and workaround) winmail.dat problem, but I am not sure why my fix works? Here is what I did:
I copied the contacts in my Outlook.com's address book and pasted them into the My Outlook Data File's address book. Next I deleted all the contacts in the Outlook.com's address book. I then proceeded to clear the autocomplete cache and restarted Outlook. Next I sent a test html email message with a PDF attached using a contact from My Data File's address book (this email was sent to another email address of mine which I use on my iPad...Yahoo address..default iPad mail client). Guess what? No winmail.dat...just the PDF.
So I copied and pasted the contacts out of My Data File's address book back into the Outlook.com's address book. Then I cleared the autocomplete cache and restarted Outlook. Next I sent another email to my iPad's Yahoo email address. This time I used the contact from the Outlook.com address book. The dreaded winmail.dat reared its ugly head again. Just to be sure, I cleared the autocomplete cache again and restarted Outlook. Then I sent another email with the same PDF attached using My Data File's address book...no winmail.dat.
What could be going on here? Did Microsoft change something on their end or what? Like I stated earlier, this all started about 2 weeks ago. Why would the Outlook.com address book cause the winmail.dat problem?
Thanks in advance!
N Please help....winmail.dat issue...slowly going insane..... Using Outlook 1
D Winmail.dat with MS Exchange Personal and Outlook.com Using Outlook.com accounts in Outlook 5
M Winmail. dat - HELP Using Outlook 2
Diane Poremsky Outlook is sending winmail.dat attachments Using Outlook 0
D Outlook 2010 Rules: fwd meeting invitation results in winmail.dat not .ics Using Outlook 4
M outlook sending winmail.dat attachments Using Outlook 6
N Create one-off that does send winmail.dat Outlook VBA and Custom Forms 3
M Dat i relativi a Business contact manager BCM (Business Contact Manager) 2
A Clipboard Resize Issue Using Outlook 7
D hide messege issue Using Outlook 1
B Outllok 2007 License Expired issue Using Outlook 0
M Calendar Time Zone issue Using Outlook 0
B My outlook calendar edit issue Outlook VBA and Custom Forms 0
D Unusual calendar issue Exchange Server Administration 0
D Multiple Accounts Issue Receiving Emails in 2016 Using Outlook 0
tswatek Issue with where Outlook saves new contacts Using Outlook 3
K Outlook with MDaemon Connectivity Issue Using Outlook 4
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
D Resizing issue for message field Outlook VBA and Custom Forms 0
P Outlook hanging issue Using Outlook 0
K Outlook 2013 calendar issue with Outlook.com Using Outlook.com accounts in Outlook 2
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
K Insert screenshots issue Using Outlook 2
B Sub Calendar-Color Coding Issue Using Outlook 4
T Using Outlook 2007 with Comcast (.pst inbox issue) Using Outlook 1
Brendan.Z Outlook 2013 signature editing issue Using Outlook 3
F Custom contact form icon issue Using Outlook 1
A Autocomplete issue Using Outlook 6
wallisellener Synch issue BCM (Business Contact Manager) 2
H Outlook 2013 size issue Using Outlook 1
C Voting Issue with Shared Inbox Using Outlook 1
J Outlook 2013 Forms Issue Using Outlook 1
A How are you handling Outlook.com category issue and syncing Using Outlook.com accounts in Outlook 2
J Outlook.com EAS Issue Using Outlook.com accounts in Outlook 6
santheocles Issue in Outlook 2013 - cannot reschedule single task Using Outlook 0
P Outlook ruler issue Using Outlook 3
