Unique ID solution for all outlook items?
Staffs Lebowski
Outlook 2013 64 bit
Windows 10 | Outlook 365
After the creation of any Outlook item (Task, Contact, Email, Appointment) I would like to create/take a unique ID (EntryID?) and save that ID to a 'custom field' (?) where I will have a permenent reference ID for that Item.
I've done a bit of searching this morning in the forum and the net but nothing comes up that seems simple. Most people want to do fancy things like connect to a database and pull numbers through or only emails. Personally, I'd be happy with a simple Date ID (YYYYMMDDHMMSS) type thing, just as long as it's unique and can be applied to all Outlook Items.
Not sure where to start. Any advice greatly appreciated.
Thank you..
StaffsLebowski
this shows how to add a custom field to selected items - Sort messages by Sender domain - to add now as the value, you'd use
strDomain = Format(Now, "yyyymmddhhmmss")
To add it to new items you create, you'll need to watch for new inspectors -
Use a Default Subject for New Messages - remove the if block that looks for new mail items and add the code to set the field.
A UID field in iCal files - unique per-event or per-user or both? Using Outlook 2
M Nested distribution lists: how to count UNIQUE # of people... Outlook VBA and Custom Forms 13
A Assign a unique number to every message I send Using Outlook 0
Z assign unique number email Using Outlook 8
J Grouping email subjects by unique indentifier Using Outlook 1
M Creating a unique appointment for later amendment Outlook VBA and Custom Forms 1
H Email unique id Outlook VBA and Custom Forms 12
U Export of Message Header / Unique ID to Excel Sheet When email is Outlook VBA and Custom Forms 1
witzker Spam Fighting Solution For 3 Synced Outlooks Outlook VBA and Custom Forms 0
O Wishlist Native solution to detach attachments but keep a link to them Outlook Wishlist 1
O VBA or other solution for Outlook tasks to OneNote Outlook VBA and Custom Forms 0
V Outlook Data File (PST) - Auto Backup Solution Using Outlook 3
S Need solution to Outlook mail handling/syncing/mobile situation, please Using Outlook 2
J Looking for a solution (maybe an add-in) to easily track email conversations Using Outlook 3
J A reporting and analysis solution for MS Exchange Exchange Server Administration 0
H Outlook 2007 - hide completed tasks from Outlook Today -Solution Using Outlook 2
A force outlook to default to MY calendar Using Outlook 3
Owl Export Outlook PDF Attachment as JPG? Outlook VBA and Custom Forms 3
A Outlook Reminders not populating for certain events Using Outlook 2
O Moving "tasks" to inbox in Outlook 2016 Using Outlook 1
Z Remove GMAIL IMAP account from Outlook 2016 Using Outlook 2
witzker Outlook 2019 Pls. add a Prefix for OUTLOOK 2019 here Using Outlook 1
H Outlook 2019 intermittent search results Using Outlook 0
hstein POP3 latest Outlook Using Outlook 0
J How to import many msg into different public folders in Outlook Outlook VBA and Custom Forms 7
A Reminder duplication Outlook and Outlook.com Using Outlook.com accounts in Outlook 5
F Moving Outlook to new PC Using Outlook 0
Ken Pascoe Outlook Categories Quick List Using Outlook 0
M All fonts in Outlook emails display with exaggerated character spacing Using Outlook 3
