Apply customized Business Card for all users
EricWa
I've gone through the article on this site about modifying a business card layout and then publishing it as a custom form and defaulting it for new contacts. Using Custom Business Cards
This works and applies the customized business card layout if I create a new contact. However what most of my users will do is 'Add to Contacts' from the global address list. In this case, the customized business card layout isn't applied.
I'm wondering if the GAL contacts have a business card layout already created, and the action 'Add to Contacts' isn't technically creating a new contact, it is just copying and existing one. If this is the case, is it somehow possible to modify the business card layout for contacts in the GAL? I would also like to customize the business card layout for all users in the GAL.
Diane Poremsky Use Word Macro to Apply Formatting to Email New Slipstick.com Articles 0
G how can Apply User-defined Field to all Sub Folder and Other Using Outlook 14
Diane Poremsky Apply Outlook Stationery to Replies and Forwards New Slipstick.com Articles 0
B Apply two rules on one email Using Outlook 2
R Rules - apply to messages > n days old Using Outlook 2
B Unable to apply rule on Exchange server functional account Exchange Server Administration 1
M Apply different views to calendars Using Outlook 0
C Apply Category Color for Appointment Background Color Calendar Printing Assistant 2
F Apply Follow up flag ONLY to the people cc'd. Using Outlook 1
T Is there a way to apply a macro before a signature is applied in email? Using Outlook 1
L Unable to apply SP1 to Exchange 2010 Exchange Server Administration 5
H Create/Apply auto formatting rules by VB? Outlook VBA and Custom Forms 2
R Apply a category to item in inbox view Outlook VBA and Custom Forms 1
witzker Customized ribbon and entries disappeared Using Outlook 0
D Customized Contact Form Losing UDFs. Outlook VBA and Custom Forms 12
G Flag for Follow Up with a customized duetime Using Outlook 1
mikolajek Add on for customized flag operations? Using Outlook 4
B Mass customized emails sent weekly Using Outlook 0
M convert/import a customized record into the default "Account" record BCM (Business Contact Manager) 0
S Outlook 2013 - Customized auto-reply message Using Outlook 10
H Date options on Customized Contact form Using Outlook 2
A POST customized as a form Using Outlook 2
G Customized field data problem BCM (Business Contact Manager) 4
B Opening a saved Outlook customized form the same folder Using Outlook 2
B Opening a saved Outlook customized form after moving it to another folder Using Outlook 2
B How to create the customized Outlook SQL DASL for selected days? Outlook VBA and Custom Forms 2
E phone numbers & addresses header disappear (customized contact) Outlook VBA and Custom Forms 7
B Customized Send button Outlook VBA and Custom Forms 5
S Display SharePoint document library in a customized Outlook form Outlook VBA and Custom Forms 1
T Customized Sensitivity Levels Outlook VBA and Custom Forms 3
U Customized Command Button Outlook VBA and Custom Forms 3
B Importing business card into Outlook for SIgnature Using Outlook 1
J Make business address defulkt in cureent not new contacts Using Outlook 1
P How to filter primary contacts in business contact manager BCM (Business Contact Manager) 0
F Set (flagged) reminder for next business day Using Outlook 4
C Business Contact Manager Using Outlook 3
Diane Poremsky How to Process Mail After Business Hours New Slipstick.com Articles 0
Diane Poremsky How to Always Process Mail After Business Hours New Slipstick.com Articles 0
Diane Poremsky Project and Business Process Management Tools New Slipstick.com Articles 0
B Business Connectivity Service BCM (Business Contact Manager) 4
