Flag for Follow Up with a customized duetime
Georgios
Exchange Server 2010
I'm trying to create a VBA flag for follow up instruction. what I've seen till now, is about creating a flag with a specific due date (+X days vs today, o similar). I need to customize the due date every time I run this macro, in order that the flag customization box opens (so i can fill in the duetime i need). is that possibile?
Many thanks in advance!
A Flag Message for Follow Up after sending Outlook VBA and Custom Forms 1
smokiibear follow-up flag fro Tasks in Outlook 2010 Using Outlook 5
A Post Form Follow Up Flag Using Outlook 4
F Apply Follow up flag ONLY to the people cc'd. Using Outlook 1
2 Flag for Follow up or create new task Using Outlook 1
S Adding follow flag for me by macro (MSO2007) Outlook VBA and Custom Forms 3
E Remove flag automatically Using Outlook 4
T Can't reposition "Flag Status" column Using Outlook 0
R Outlook 365 update sets delete from server flag Using Outlook 2
C-S-R How to clear an Outlook (To Do) Task Flag? Using Outlook 8
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
Diane Poremsky How to Easily Change the Private Flag Using Outlook 0
A Flag outgoing email messages in Outlook 2010 Outlook VBA and Custom Forms 0
mikolajek Add on for customized flag operations? Using Outlook 4
B on flag message event - create task Outlook VBA and Custom Forms 22
A Custom Flag Form Outlook VBA and Custom Forms 2
mikecox Missing alarm flag Using Outlook 2
D Create additional custom flag descriptions (other than Send E-Mail, Call etc.) Using Outlook 1
S Flag Completion Using Outlook 0
A automatically remove flag from original message when a response was received Using Outlook 2
J Macro to periodically sort emails by flag status? Using Outlook 1
L Flag settings Using Outlook 1
M Flag outgoing mail by word in body Outlook Wishlist 1
D Setting the Reminder flag in VBA for e-Mails sent to users Outlook VBA and Custom Forms 5
C Outlook 365 Can you change the follow up colour? Using Outlook 1
O Outlook 2016 follow-up flags--how can I add dates? Using Outlook 1
G Follow up and Using Outlook 1
K check for sender, follow to my personal adress and delete the sent folder. Outlook VBA and Custom Forms 1
oliv- HOW TO GET PROPERTIES FOLLOW UP Outlook VBA and Custom Forms 7
D No Follow up when making new form Outlook VBA and Custom Forms 2
rc4524 Create auto follow-up reminder email for already sent messages Outlook VBA and Custom Forms 1
