re-Attaching PSTs after upgrade to 2016
mattR
We are gearing up to deploy Outlook 2016 (upgrading from 2013) and it seems that PSTs need to be attached manually. Is there a tool or option to automatically attach it (800+ users, probably about 100 have locally attached PSTs)
R Shortcut for attaching the same file repeatedly Using Outlook 6
P Outlook Randomly Not attaching (attachment file) Using Outlook 0
D Attaching date named files Using Outlook 3
L Creating a Task from Email and Attaching Original Email Outlook VBA and Custom Forms 6
D Attaching email conversations to tasks Using Outlook 2
A Attaching mail items in Outlook 2010 Outlook VBA and Custom Forms 5
J Attaching Files to Outlook Outlook VBA and Custom Forms 1
D Tab Order Out of Sequence After Attaching Document Outlook VBA and Custom Forms 1
H attaching e-mails to new e-mail using VBA Outlook VBA and Custom Forms 1
RBLampert Combining PSTs Using Outlook 1
J DisablePST = 2 : Only Sharing-Exclusive PSTs can be added Using Outlook 1
C My Outlook PST size is about 19GB, how can I seperate it into small size of psts? Using Outlook 3
T AdvancedSearch & PSTs Outlook VBA and Custom Forms 5
T upgrade from outlook.com to Outlook Using Outlook 2
T How do I upgrade from outlook.com to Outlook? Using Outlook 5
M Upgrade in Progress. Your mailbox is currently being optimized as part of upgrade to Outlook 2010 Using Outlook 9
E Upgrade Issues - Office/Outlook 2007 to 2010 Using Outlook 0
Diane Poremsky How to Upgrade to Color Categories New Slipstick.com Articles 0
P Outlook 2013 search broken after upgrade from 2010 Using Outlook 0
W Outlook 2013 - 2nd acct stopped receiving email after Win 8.1 upgrade Using Outlook 3
U BCM upgrade help BCM (Business Contact Manager) 0
F Which upgrade should I go for and how do I do it please? Using Outlook 2
H Outlook 2010 unable to send iCloud account e-mail after iOS 7 upgrade Using Outlook 12
B Two Inboxes after upgrade, how to merge? Using Outlook 4
L Outlook 2002-2013 upgrade Using Outlook 3
Horsepower Upgrade advice needed Using Outlook 3
T Outlook 2010 keeps asking password after upgrade Exchange Server Administration 1
B Upgrade 2003 to 2010 and max pst file size of 2GB Using Outlook 2
J Upgrade from 2003 to 2007 Outlook VBA and Custom Forms 14
S Upgrade Outlook 2007 to outlook with Buisiness Contact m|Manger BCM (Business Contact Manager) 2
E How to restore BCM Database after upgrade from Vista to Win7? BCM (Business Contact Manager) 1
B Upgrade to 2007, Action stopped working Outlook VBA and Custom Forms 3
A Upgrade to 2007, lost 'Accounts' info BCM (Business Contact Manager) 1
B Upgrade 2003 BCM to 2007 BCM BCM (Business Contact Manager) 3
J BCM no longer loads sqlserver after SP2 upgrade BCM (Business Contact Manager) 2
T Custom form created in 2003 won't print since upgrade to 2007 Outlook VBA and Custom Forms 1
T Custom form created in 2003 won't print since upgrade to 2007 Outlook VBA and Custom Forms 13
