Folders shifting around in Outlook 2013 and 2016
Rob Madison
Outlook 2013 64 bit
Exchange Server 2010
Having an odd issue with one email account...
Background:
Using Hosted Exchange via Rackspace.
Server is Exchange 2010
Outlook versions affected: 2013 & 2016
Both are running the latest updated versions.
I have 2 users accessing the same email account called 'compliance'. One is on OL 2016, the other is on OL 2013.
The folders in that account shift around by themselves. This isn't in the "Favorites" area either. One moment 'Inbox' is on top. The next moment, 'Deleted Items' will be on top, then another, etc. At one point on my OL 2016 user, the 'Inbox' and 'Junk mail' folders just start swapping positions rapidly and Outlook hangs.Then we get the "Not Responding" dialog box asking us if we want to restart Outlook.
My OL 2013 user sees the folders shift around, but Outlook never hangs and she doesn't see the rapid position change my OL 2016 sees.
What I've tried:
Turning off all mail handling rules for both users
Starting in safe mode
Creating new profile with just the 'compliance' address.
Current work around:
Removed the compliance email from my OL 2016 users profile.
Granted her work email account 'Both' (Full Access and Send As) permissions to the compliance account.
Disadvantages with that work around:
Can't recover deleted email
Any email sent using the compliance address goes into her work accounts "Sent Items" folder. They do not go into the compliance Sent Items folder.
Other:
This folder shifting behavior began after I removed the 'Both' permissions from each user's work accounts and added the compliance account on their computers.
Sorry I missed this - it's the Sort Folders A-Z command.
F VBA to move email from Non Default folder to Sub folders as per details given in excel file Outlook VBA and Custom Forms 10
A Moving Public Folders to New Database Exchange Server Administration 3
Paul Hobbs Automatically accept "Empty Folders" prompt Outlook VBA and Custom Forms 6
D How To Combine Share Task Folders in just one Folder Using Outlook 0
witzker print-list-of-outlook-folders with sort posibility Outlook VBA and Custom Forms 7
vodkasoda Hiding empty Folders Outlook VBA and Custom Forms 0
GregS Outlook 2016 Sent Mail absent from Sent Mail or Sent Items Folders Using Outlook 4
R The way expand/collapse folders is actually meant to work? Using Outlook 2
L Merge two contacts folders Using Outlook 1
E Project Management - Adding Folders for Different Folder Types Using Outlook.com accounts in Outlook 0
GregS Many Sent Item folders Using Outlook 3
B Reorder folders in Outlook Outlook VBA and Custom Forms 1
D [TOOL] QuickModules to sort emails very quickly to multiple folders Outlook VBA and Custom Forms 1
T Some of my folders in outlook.com appear to have vanished, thanks to v1803 Using Outlook 11
N Tracking Mail items being moved to folders Outlook VBA and Custom Forms 5
oliv- FASTEST METHOD TO ENUMERATE FOLDERS Outlook VBA and Custom Forms 3
F Search folder for tasks in all task folders Using Outlook 1
copperberry How to view all tasks across task folders Using Outlook 3
O Extracting all mail addresses from all folders Using Outlook 10
O Set columns for all (sub)folders Using Outlook 8
M cannot change delivery folders with IMAP accounts Using Outlook 0
