Inserting sender name and address with vba
Dean Waring
I am trying to create emails using vba. I get the email created with the To:, Subject:, Body:, and attachments just fine but none of the examples that I've searched and researched seem to show the sender's name, address, phone or anything like that. For instance:
Public Sub sendmeTest()
Dim objOutlookMsg As Outlook.MailItem
Dim objOutlookRecip As Outlook.Recipient
Dim obj As Outlook.MailItem
Set objOutlook = GetObject(, "Outlook.Application")
Set objOutlook = CreateObject("Outlook.Application")
Set objOutlookMsg = objOutlook.CreateItem(olMailItem)
With objOutlookMsg
Set objOutlookRecip = .Recipients.Add("John.Smith@td.com")
objOutlookRecip.Type = olTo
.Subject = "Monthly Reports"
.Body = "Attached are this month's monthly reports. Let me know if you have any questions."
.CC = "Allison.Jones@td.com"
.Importance = olImportanceNormal
DisplayCurrentUser
' .Send
.Display
Set objOutlookMsg = Nothing
Set objOutlook = Nothing
Set objOutlookRecip = Nothing
This creates the email very nicely, but doesn't have sender details. Any thoughts?
W Inserting Additional Email Address Outlook VBA and Custom Forms 4
D Using Libraries when inserting a file in Outlook 2013 Using Outlook 1
L Inserting a PPT/PDF into the message body Using Outlook 1
B Outlook 2007 - Slow opening folders when inserting attachments Using Outlook 2
S Inserting Dates With Quick Parts (or Macros) Using Outlook 4
L Block others from inserting appointments in your calendar Using Outlook 3
W inserting activeX/user control into form Outlook VBA and Custom Forms 1
H C# inserting word document with formatting into outlook message Outlook VBA and Custom Forms 1
R Inserting a hyperlink in the bod of an outlook appt. Outlook VBA and Custom Forms 13
K Inserting text from a macro Outlook VBA and Custom Forms 1
L Checking Sender Email Address for trusted domain from list on intranet Outlook VBA and Custom Forms 4
R Capture Sender's Display name and Address Outlook VBA and Custom Forms 3
J Outlook 2016 How tell Outlook not to trust sender? Using Outlook 1
M Screen Scrape Sender IP Address Outlook VBA and Custom Forms 6
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
D Moving Emails Based on Recipient/Sender Outlook VBA and Custom Forms 4
A Sort emails into subfolders based on sender and deleting emails automatically Outlook VBA and Custom Forms 3
Ed Sheehan Unusual behaviour in setting Sender (Outlook 2016) Outlook VBA and Custom Forms 4
M Move new mail to folder based on sender address Outlook VBA and Custom Forms 2
M Blocked Sender List @Domain Not Working Using Outlook 0
B Can't expose sender email address when linking outlook to access Using Outlook 3
Diane Poremsky Use VBA to create an Outlook Search Folder for Sender Using Outlook 0
K Extract email to excel from a specific sender Outlook VBA and Custom Forms 3
O See recent emails from a sender Using Outlook 2
S announce email sender and subject when new email arrives... Using Outlook 7
K check for sender, follow to my personal adress and delete the sent folder. Outlook VBA and Custom Forms 1
P Mail delivery failed returning message to sender Using Outlook 1
K Outlook moves sender's mail, but there is no rule Using Outlook 0
