Retrieve data from GAL and put it in Clipboard
Martin69
i have already a script that works fine - but i would like to habe a few changes.
the script displays an outlook contact, that was searched by the email adress.
Now i want the following changes:
1) get some Information out of the selected item e.g. department
2) this Information should automatically put in the clipboard
Can somebody help me - thank you!
Sub DisplayAddressEntryDetails(oM As MailItem)
Dim oPA As Outlook.PropertyAccessor
Dim oContact As Outlook.ContactItem
Dim oSender As Outlook.AddressEntry
Dim SenderID As String
'Create an instance of PropertyAccessor
Set oPA = oM.PropertyAccessor
'Obtain PidTagSenderEntryId and convert to string
SenderID = oPA.BinaryToString _
(oPA.GetProperty("http://schemas.microsoft.com/mapi/proptag/0x0C190102"))
'Obtain AddressEntry Object of the sender
Set oSender = Application.Session.GetAddressEntryFromID(SenderID)
'Examine AddressEntryUserType
If oSender.AddressEntryUserType = olOutlookContactAddressEntry Then
'Obtain ContactItem for AddressEntry
Set oContact = oSender.GetContact
oContact.Display
'Display details for Exchange or SMTP sender
oSender.Details
N How to retrieve user defined fields values to bcm form. Using Outlook 2
F Auto retrieve wont work Using Outlook 1
Chris Smith Outlook 2013 will not retrieve my IMAP mail Using Outlook 1
4 VBA - How to retrieve Meetings Saved but Not Sent? Using Outlook 0
K Outlook favorite folder disappear, how do I retrieve it back? Using Outlook 0
I Retrieve amount of calendar availability and attachments automatically Using Outlook 2
G Cannot retrieve emails past 2 weeks old Exchange Server Administration 1
R Went from outlook 2003 to 2010 - can't retrieve active for contacts Using Outlook 0
P Retrieve Meeting Response Text Associated with an Appointment Outlook VBA and Custom Forms 1
P CDO MAPI Session failing to retrieve user name but Getexchage user Outlook VBA and Custom Forms 2
J Could not retrieve IMessage: Interface not supported Outlook VBA and Custom Forms 7
S Retrieve the Mails with the attachment names changed Outlook VBA and Custom Forms 3
T Re: mailItem.HTMLBody should retrieve only current text Outlook VBA and Custom Forms 1
J Deliver new messages to New or Existing Data File? Using Outlook 2
D Outlook 2016 Unable to load Outlook data pst file Using Outlook 5
V Form data not sending for some users Outlook VBA and Custom Forms 2
T Extract Data From Outlook Tasks Using Outlook 0
F outlook.com Exchane Server corrupts data Since September 2019 Using Outlook.com accounts in Outlook 6
C How to export Outlook data to csv? Using Outlook 0
RBLampert Assigning a newly (re)created e-mail account to a specific .pst data file Using Outlook 2
S newly added shared mailboxes downloading 500GB data a day Exchange Server Administration 1
M Outlook 2016 Requesting data from server Using Outlook 0
Sofia Manni Some of my favorite data in outlook. Using Outlook 2
A Outlook 2016 Will Not Show Any Data In the People Pane Using Outlook 17
Commodore Search cannot complete the indexing of your Outlook data Using Outlook 6
P Microsoft Outlook is requesting data from the server Using Outlook 2
