warning for too many appointments on a same day in Outlook
maddygy
Recently I scheduled too many appoitments in a same day. And I really don't have enough time to deal them all.
So I want to set a limit to the number of the appointments on one day in Outlook. For example . When the number of the appointments on the same day is over 6, Outlook will give me a warning to tell me that there are too many appointments on that day. How can I do this?
Well, you'd definitely need to use a macro. it would need to do a lookup on the calendar of the day - probably as you save the appointment, then it can tell you are at 6 and cancel the save. i don't have any code samples that do it though.
C WARNING - DO NOT USE AN OUTLOOK.COM ADDRESS FOR GOOGLE ACCOUNT RECOVERY EMAIL Using Outlook 10
A Warning When Opening attachment Using Outlook 7
J Customize Attachement Security Warning Using Outlook 1
Diane Poremsky Meeting Location Warning Message Using Outlook 0
D Conflict warning while editing Exchange Server Administration 0
Diane Poremsky Disable the Unsafe Hyperlink Warning when Opening Attachments Using Outlook 0
Jack Poore Outlook gives warning using GO Contracts Sync Mod Using Outlook 4
M Rule to pop a warning dialogue on certain actions Using Outlook 1
Rory Campion Not getting a warning when a shared calendar item has been updated by someone else Using Outlook 2
B How do I get a warning before deleting e-mail messages? Using Outlook 2
J Disable outlook 2010 no-subject warning Using Outlook 4
E Disable outlook 2010 no-subject warning Using Outlook 9
T Missing attachment warning Outlook VBA and Custom Forms 1
T Warning message Outlook VBA and Custom Forms 3
F No Attachment Warning - VBA Code HELP Outlook VBA and Custom Forms 1
H How turn off outlook security warning dialog box from outlook Outlook VBA and Custom Forms 1
P Stopping that security warning Outlook VBA and Custom Forms 1
1 Warning messege Outlook VBA and Custom Forms 3
AmonRa Outlook 365 calendar - too much white space Using Outlook 0
L Outlook saved template function too limited Using Outlook 2
D Too many scripts? Outlook VBA and Custom Forms 1
GregS Outlook 2016 Too Many Archives Using Outlook 0
C too many choices for time zones! can i reduce to actual time zones only? Using Outlook 1
B Calendar shows too much info by default Using Outlook 0
M Charter ISP Claims Outlook Generating STMP Errors of Too Many Recipients Using Outlook 1
D Meeting Request - Too Many Recipients Using Outlook 0
Diane Poremsky "Too many files" Error Message Using Outlook 0
V Your Imap server wants to alert you to the following: Message too large Using Outlook 4
A Importing too many emails from Gmail Using Outlook 2
S New Quick Step based on Team email QS - automatically update too Using Outlook 1
V IMAP: email is too large Using Outlook 1
mikecox Too many "contacts" lists Using Outlook 2
J Contact page too large for screen. Can't see categories, etc. Using Outlook 1
J Microsoft Outlook 2007 Font Size Too Small Using Outlook 1
A My move to MS is not going too well: Need Help !!! Using Outlook 14
M Font Size Too Small When Replying and Sendig Emails on Outlook 2007 Using Outlook 1
R Too Many Devices Using Outlook 2
G Opening messages takes too long Using Outlook 5
S too difficult of a question to google Using Outlook 2
E OWA phones home too much? Exchange Server Administration 1
S Using Scanpst too often? Using Outlook 2
R Too many folders in Outlook 2013 Using Outlook 11
H Too simple I would think but.. Using Outlook 1
D Navigate to my calendar. Too many steps Exchange Server Administration 2
J Contacts in 32bit 2010 filled with Bounce Emails (and contacts too)! Using Outlook 1
