How to set fonts for emails in all folders in Outlook
e_a_g_l_e_p_i
I would like to have the same font and size for emails in all folders, for some reason I have different size fonts in different folders. Both examples are folders that I save emails to. You can see the dates are not blurred out and you can see in folder 1 the fonts are small and in folder 2 they are bigger ?? Not sure how I got some to be bigger and others remain small.
Is there a place in Outlook 2010 to make all emails in all folders have the same font and size ?
That is a view setting - View tab - you can change the view on a folder by clicking the View settings button but it's usually better to expand the current view button and choose manage views -the edit the view in the list by name (not the 'current view' entry).
O Cannot expand the folder. The set of folders cannot be opened. You do not have permission to log on. Using Outlook 1
e_a_g_l_e_p_i Outlook 2010 How to set default email address for website links Using Outlook 3
F how do i set a reminder in onenote 2010 Using Outlook 8
J Set Timer/Countdown on Emails? Outlook VBA and Custom Forms 3
Victor_50 Set all subfolders to not autoarchive Outlook VBA and Custom Forms 11
e_a_g_l_e_p_i Can you set reminder to specific times? Using Outlook 7
CWM030 I do not see a way to set the personal archive folder Exchange Server Administration 2
O Set columns for all (sub)folders Using Outlook 8
F Set (flagged) reminder for next business day Using Outlook 4
L how to set downloaded cached emails Using Outlook 5
S set a flag task date as the next weekday Outlook VBA and Custom Forms 4
Diane Poremsky Set Another Data File as Default When Using an Exchange Account Using Outlook 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
C Outlook VBA to set current account Outlook VBA and Custom Forms 1
Diane Poremsky Add Attachments and Set Email Fields During a Mail Merge Using Outlook 0
O How to set subject line in replies using VBA Outlook VBA and Custom Forms 1
A Custom form not showing when recurrence is set for a meeting Using Outlook 0
M Exchange 2013 On premise set MessageRateLimit for User has no effect. Exchange Server Administration 0
A Block user to send emails to specific set of email ids Using Outlook 1
D Outlook 2007 e-mail header- How to set font & font size in received message headers ? Using Outlook 2
Diane Poremsky Exchange account set-up missing in Outlook 2016 Using Outlook 0
M To set the storage folder for an outgoing Outlook message Outlook VBA and Custom Forms 8
E Meeting reminders are set for the recipient Exchange Server Administration 9
M Help! Can't set up IMAP for gmail Using Outlook 2
P Last Change attribute set after viewing a public folder contact Exchange Server Administration 0
S Multiple Gmail account set up in Outlook 365 Using Outlook 1
Diane Poremsky Add attachments and set email fields during a mail merge to email Using Outlook 0
D Script to parse email and set a task Outlook VBA and Custom Forms 1
K Outlook 2010 - Set the category based on category of other emails in same conversatio Using Outlook 20
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
A set onedrive calendar as default in Outlook Using Outlook.com accounts in Outlook 4
