Outlook incompleted tasks has strike through
Angela Giles
Outlook 2016 64 bit
Outlook 2016 incompleted tasks has strike through as if it has been completed. I have remove the ost files and the task are the same. I have change the conditional formatting to remove the strike through but the percentage reads 100% like has been completed. How do I resolve this?
Angela Giles
Outlook 2016 64 bit
Its showing 0% with the strike through the task. No, the tasks are under the task checkbox option in outlook 2016.
Did you reset the view or just change the one conditional format? I'd try resetting the view.
H Outlook 2016 related mails in outlook Outlook VBA and Custom Forms 0
@ Outlook Using Outlook 2
O Outlook 365 - Gmail and Outlook: how to force Outlook to start up in Gmail? Using Outlook 2
M Seeking PDF Recommendation for Outlook that retains links Using Outlook 7
P How can I stop Outlook 365 duplicating the posts? Using Outlook 2
