Unread Until Click Another Message?
Outlook 2016 64 bit
If I click an email and read it then click delete, it shows unread message in my trash. I have to click another emails first then go back to the email I want deleted before it can be sent to the trash as read.
How can I set Outlook to mark a message as read as soon as I click on it and while it is still highlighted? Usually I have a few emails but right now I have zero emails in my inbox. So when I get one I have nothing else to click to deselect the email, I have to go into sent or trash or another folder then come back to inbox THEN delete the email.
I do not like seeing a # next to Trash.
Ctrl+Q will do it manually, or you can change the setting in View tab, Reading pane, Options. You probably want Mark as read when viewed nn seconds. 5 seconds is usually a good value so it doesn't get marked as read too quickly.
T E-mails marked as read turn back to unread after a couple of seconds Using Outlook 1
J Old unread emails on current date (MDaemon Server) Using Outlook 1
S Mark as Unread unless Categorized by Color Using Outlook 0
C Unread email count not displaying on Inbox sub-folders Using Outlook 0
F Automatically close email after selecting mark unread Using Outlook 1
B Unread Undead Using Outlook 1
Commodore Message becomes "unread" after moving to a local folder Using Outlook 2
B Unread, undead Using Outlook 7
L Outlook keeps my messages as unread Using Outlook 1
T Unread messages not in bold Using Outlook 0
T Unread messages do not show up in bold Using Outlook 0
P Overall inbox folder, overall unread folder Using Outlook 3
Z Keep Unread Messages in same folder Using Outlook 2
M Automatically highlight unread mail in Favorites inbox(s) (Blue number) Using Outlook 1
L Auto printing unread email + attachments in Inbox - Outlook 2010 - (New user) Using Outlook 1
J Outlook saves canceled messages in Deleted folder as an unread message Using Outlook 1
W Email becomes "unread" after replying to it. Using Outlook 8
G How to make outlook show as unread messages I read in my mobile ph or tablet Using Outlook 1
M Problem/Glitch with unread mail and going back to inbox --- missing emails Using Outlook 1
B Messages stay marked unread Using Outlook 2
K Read, unread, i'm losing clients! Using Outlook 1
M Folder View in Unread Mail Pane - Outlook 2003 Using Outlook 6
A How to Sort by Unread and then Read mail in Outlook 2007 Using Outlook 7
R Macro to mark item unread Outlook VBA and Custom Forms 2
B get the total unread mails Outlook VBA and Custom Forms 1
F not receiving emails until i re-login Using Outlook 2
T Outlook 2016 is not receiving emails until I restart it Using Outlook 1
P Outlook 2007 not sending/receiving until restart (send/receive stuck at __%) Using Outlook 27
C New emails not appearing until Outlook is closed and re-opened Using Outlook 5
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
B Open a folder / subfolder of a PST in single click Outlook VBA and Custom Forms 4
Diane Poremsky Contacts are missing when you click the To button Using Outlook 0
M Office 365 Click to run BCM (Business Contact Manager) 0
