other user's mailbox won't open, forms disappeared
mr_malkovich
It's weird. I'm just noticing in the bottom right Outlook progress bar that it's saying 'updating judy@mydomain.com sent items'. So that suggests something is happening. Could it be that it really is just... busy? Busy or not busy, I've never had a hint of these problems with the other shared mailbox.
Also now noticing that my error messages alternate between 'the set of folders cannot be accessed. microsoft exchange is busy' and 'the set of folders cannot be accessed. james@mydomain.ost is in use'
Read somewhere to look out for ucmapi.exe in the task manager because apparently that's Skype for Business and lo and behold..
that is the file that handles the skype integration with outlook. Try disabling all of the integration in options (screen shot i posted earlier)
mr_malkovich
Did all that a week ago. Also hunted down and disabled Skype Meeting Add-In in Outlook, and just uninstalled regular old Skype for good measure. Still stuck.
mr_malkovich
Someone with the same problem posted this on another forum a while back. Do you think this could be it? I'm in my domain name's cname records and don't see autodiscover records.
Okay after reading some other Office 2016 shared folder issues with Office 365 our issue the fact the shared inbox was associated with a domain other that our primary domain.
The domain that the shared inbox was associated with did not have autodiscover records.
Added the following records to our domain fixed things for us:
autodiscover IN CNAME autodiscover.outlook.com.
msoid IN CNAME clientconfig.microsoftonline-p.net.
This wasn't at issue with previous versions of outlook but it seems to matter with Outlook 2016.
Hope this helps out someone else with the same sort of problem.
Yes, it is potentially the issue - the article is correct, you need autodiscover records for all domains used in outlook.
mr_malkovich
Again, I have another colleague mailbox I've been accessing for years without a hitch.. But alright.. just threw the CNAMEs in. Look okay? Propogation time hopefully won't be 24 hours.
Yes, looks good. Whether it will fix the problem, who knows, but now its properly configured in DNS. :)
mr_malkovich
Added these CNAMES last night and enjoyed a couple hours of full folder availability. Went to sleep happy. Woke up and looked at my laptop, dreading the moment I opened Outlook because I just knew it wouldn't last. And it didn't. Same problem, back.
Remind me again... how many people are having this problem? That can give us an idea if it’s your outlook or the server.
mr_malkovich
You mean within my organization? Well, until a couple of days ago, I was only having this problem with one colleague's mailbox. But now it's both.
yeah... was wondering if everyone had problems or just some users.
mr_malkovich
The problem just keeps growing. Now my Exchange notes won't sync with my phone. Also, I can't access 'Contacts' from the 'Select Names' screen when I click 'To' on an email reply. Add that to not being able to access other users' mailboxes, and not being able to access my Personal Forms, and it just seems like I've lost all kinds of permissions to my own Office365 setup.
mr_malkovich
Accessed Powershell. That top line under NT AUTHORITY says false and false to james account having full access. So I assume that's the problem here. But according to my Outlook and my OWA too, that account has full permissions. What do I do?
ModuleType Version Name ExportedCommands
Script 1.0 tmp_maoui35w.r51 {Add-AvailabilityAddressSpace, Add-DistributionG...
PS C:\WINDOWS\system32> Get-MailboxPermission judy@domain.com
Identity User AccessRights IsInherited Deny
jp NT AUTHORITY\SELF {FullAccess, ReadPermission} False False
jp james@domain.com {FullAccess} False False
jp NAMPRD06\Administ... {FullAccess} True True
jp NAMPRD06\Domain A... {FullAccess} True True
jp NAMPRD06\Enterpri... {FullAccess} True True
jp NAMPRD06\Organiza... {FullAccess} True True
jp NT AUTHORITY\SYSTEM {FullAccess} True False
jp NT AUTHORITY\NETW... {ReadPermission} True False
jp S-1-5-21-15893167... {ReadPermission} True False
jp PRDTSB01\JitUsers {ReadPermission} True False
jp NAMPRD06\Administ... {FullAccess, DeleteItem, ReadPermission, Chang... True False
jp NAMPRD06\Domain A... {FullAccess, DeleteItem, ReadPermission, Chang... True False
jp NAMPRD06\Enterpri... {FullAccess, DeleteItem, ReadPermission, Chang... True False
jp NAMPRD06\Organiza... {FullAccess, DeleteItem, ReadPermission, Chang... True False
jp NAMPRD06\Public F... {ReadPermission} True False
jp NAMPRD06\Exchange... {FullAccess, ReadPermission} True False
jp NAMPRD06\Exchange... {FullAccess, DeleteItem, ReadPermission, Chang... True False
jp NAMPRD06\Managed ... {ReadPermission} True False
the yellow notes or the notes field in contacts?
Do you have full mailbox access or just to specific folders? (can see everything in the mailbox or just certain folders)
Are you the administrator? If you have admin rights to Office 365, log into the Exchange portal at Sign in to your account and check the permissions on the mailbox. Full Access permission shows everything.
I'm guessing the ps is showing that field on judy's mailbox doesn't have James name.... (and you just have permissions on specific folders).
mr_malkovich
The yellow notes have been syncing with a folder called 'Exchange' in my iPhone's Notes app until recently.
Through OWA I have access to both my colleagues' inbox and all other folders within that tree (sent items, deleted items, etc.)
I have full access. Check the attached screenshot.
Did you check the results from Powershell that I posted earlier? Specifically the line that goes:
definitely looks fishy there..
Yes, Exchange accounts will sync the sticky notes if they are set up in the phone's native apps - i have my accounts set up in both outlook app and the native app to get the notes (and turned off sync for everything else). (Outlook.com notes will sync too, but you may need to add it as an exchange account, not outlook.com)
It's just notes that no longer sync?
I was thinking the fishy part was due to how access was given - by the mailbox owner in outlook (right click on folder > properties > permissions) instead of via the admin portal. Since it looks like it was given in the portal, its definitely fishy.
mr_malkovich
How do I fix it?
How do I fix it?
I'm not sure, since we don't know the reason it is messing up.
Without going back over page 1 (yeah, i'm lazy... :)) - this is a shared mailboxes, in the profile as shared mailbox, not as separate account, correct?
Is the mailbox automapped - as in, it just shows up in the profile automatically? If it is automapped, opening it account settings > exchange account > more settings > advanced tab as a secondary mailbox can cause weird behavior, as can opening it as an account if it is also shared with another mailbox in the profile.
mr_malkovich
Hi. Well... GoDaddy had me create a new OST which solved the problem for two great weeks, but now it's back. Yes, both mailboxes are automapped. So it's normal for weird behavior in this situation? Well.. thanks Microsoft. Anyway, this is more than just the automapping issue. As I mentioned before, when this problem is in effect, I can't even do things like access Contacts from the 'To' button in a new email. I get the same error message about the file being busy or whatever. So this seems to be deeper than that.
C Changed By field not displaying individual user's name in O365 Shared Mailbox Using Outlook 9
I shared mailbox - can i create a rule (vba) for every user? Outlook VBA and Custom Forms 1
T Messages no longer move to quote folder on shared mailbox after user adds -D to folder name Outlook VBA and Custom Forms 1
J Cannot copy outlook form to mailbox of exchange 2k13 user Exchange Server Administration 1
M How do I retrive User permissions for a Mailbox? Outlook VBA and Custom Forms 4
icacream Outlook 2016 “Enter your user name and password for the following server.” Using Outlook 5
N Item cannot be saved because it was modified by another user or window, and, Item could not be moved... Using Outlook 0
D Outlook 2010 Outlook in Windows 10 keeps asking for user name and password repeatedly Using Outlook 14
icacream Enter your user name and password for the following server. Using Outlook 4
R Creating a user defined function Outlook VBA and Custom Forms 3
M How to export Voting Results with user names and their responses Outlook VBA and Custom Forms 13
G <mailto:user@domain.com<mailto:user@domain.com<mailto:user@domain.com>>> Using Outlook 5
F MAPI, User Defined Fields and perspective after 20 years Outlook VBA and Custom Forms 0
A Created a new user account and the local account cannot see email Using Outlook 3
Daniel Schunk User-defined form arrives empty at the recipient Using Outlook 3
R Prompt asking the user to send email to folder as *.msg file Outlook VBA and Custom Forms 1
N Select a folder in a user account Outlook VBA and Custom Forms 2
S Outlook User defined date field (UDF) not syncing Using Outlook 2
M Multiple User Defined Fields that can be added, changed, updated using VBA and user form Outlook VBA and Custom Forms 0
S how to set user properties to a newly created appointment Outlook VBA and Custom Forms 12
S VBA with User Defined fields Outlook VBA and Custom Forms 9
D Unable to Send On Behalf of Another User Exchange Server Administration 0
M Exchange 2013 On premise set MessageRateLimit for User has no effect. Exchange Server Administration 0
