Several questions regarding Outlook 2013
Rupert Dragwater
Outlook 2013 64 bit
I've several questions regarding Outlook 2013. One is, when I reboot the computer, Outlook will automatically come up on its own. I've noticed when I shut it down and if I hurdle over to Taskmanager, under Details, Outlook is still up and running. Is there then a way when I shut Outlook down, it can be completely closed out so when I reboot the machine, it does not automatically pop up on its own.
Second question: I've been noticing when I download mail (I have this set to download every minute) nothing shows up at times but when I click on a particular email address, then the mail will suddenly show up. I've not noticed this before till as of late. This is a gmail account.
Third question: When I start Outlook, another email address pops up at the top of the screen, asking me for the Password. If I cancel it, it works ok. But I'm wondering why that particular address pops up. It's an Outlook.com address. I've done a repair on this but it made no changes.
Rupert Dragwater
Outlook 2013 64 bit
Maybe I should have kept my questions down to 2. Sorry to have stuck the whole lot of ya's!
Nah... 3 is find I've just been busy and didn't get an email notice for your message.
This is on windows 10? It's either a bug or a feature. :) Unless they build the switch into windows (i think its working in the insider builds now), you can use a shortcut to close windows - %WINDIR%\system32\shutdown.exe /s /hybrid /t 0.
Outlook automatically opens when the computer boots
1 minute is too frequent. Set it to 5 minutes. Do you have it configured as pop or imap? Imap will sync a folder when you click on it, even if its not the scheduled send/receive time.
It's hard to say why its doing it.. but there have been issues with outlook.com address, especially if you use 2-factor auth.
Rupert Dragwater
Outlook 2013 64 bit
There we go! Thanks for chiming (or humming) in on this Diane. Your fix for my first question only created an error when trying to close down Windows or the computer. Plus it made the FN / F9 stop controlling the mousepad. I had to reboot. I thought it might be that I didn't copy the period at the end of the shortcut so that also and no way would that do anything. :)
Secondly, I have an email which is a POP & another which is IMAP. This is a problem I've only had for the last couple weeks.
Thirdly,I'm not using a 2-factor authentication. This also is something about 2 weeks of age. It might be as you say, one of those weird and wonderful outlook.com addresses.
What to you think? :) And oh yes, as to not coming in on this earlier, I expect everyone to drop whatever their doing and come to my aid immediately! :)
Seriously, I figured you were tied up somewhere or maybe in Hawaii for a few weeks! :) Thanks for your always appreciated help Diane. :)
I haven't used it, because i avoid rebooting and am trying to do better about closing windows when i do. When windows reboots to install updates, i don't mind that it reopens everything.
Thisi s the setting that controls it - i was added some time ago but wasn't working. I don't reboot enough to know if it is working now. :)
its definitely not a typical behavior for pop. Have you tried resetting the view?
I have seen a lot of password/login issues with outlook.com accounts beginning about that time.... the usual answer is to delete the credentials from credential manager - sometimes it hwlps, sometimes it doesn't.
Rupert Dragwater
Outlook 2013 64 bit
A couple more questions Diane. If I shut off the "Use my sign in info" to off, how does that effect the computer on a reboot? Is it going to stop the system starting up as usual and asking for the PIN or the Password.
Second question: what is and how do I reset the view? I mean by that, when I click on that, nothing happens and I guess it can't because it's like it's grayed out.
Third question: what are the exciting results should I delete the credentials from the Credential Manager? Do I have to put passwords into each email address again etc.
From Mr Paranoid.
i have not noticed any issues here. it seems to be working in my Windows version (Insider Fast) - i don't know if it works in the general availability builds.
You just click on it- if it doesn't do anything, then its not yet enabled in your build.
Yes, for the ones you deleted, but only delete the entries that contain the email address.
Rupert Dragwater
Outlook 2013 64 bit
Ok! Copy that! Thank you so much Diane for your always excellent help. You're the best and remind your husband after you read this. Tell him something like, "You're very fortunate to have met me!" I find things like that always help in a marriage! :)
Rupert Dragwater
Outlook 2013 64 bit
Diane, here's an update as to my third question I had asked you. It was as follows:
For some weird and wonderful reason, I just noticed (or received) a notice that said the following. This was dated back back on the 22nd of March. Why I'm just noticing it now is beyond me, other than I'm a man.
Verify your account.
We detected something unusual about a recent sign-in for the Microsoft account @outlook.com. For example, you might be signing in from a new location, device, or app.
To help keep you safe, we've blocked access to your inbox, contacts list, and calendar for that sign-in. Please review your recent activity and we'll help you secure your account. To regain access, you'll need to confirm that the recent activity was yours.
Review recent activity
I got a code and checked everything and simply logged out. I shut down Outlook 2013 and when I restarted it, the particular email address was not asking for the Password anymore.
Thought I should throw that info over to you just to let you know I made a mistake and did it right. Thanks again for your help. :)
Cool. Thanks for the update. I don't usually see that as a cause with outlook.com but see it often with gmail accounts.
O flagging replies - several questions Using Outlook 2
G Updating VbaProject.OTM on several users Outlook VBA and Custom Forms 3
mctabish Replying to an email if received in several inboxes Outlook VBA and Custom Forms 2
Diane Poremsky Assign one task to several people Using Outlook 0
C Further automate several tasks with rule, VBA or Quick Step Using Outlook 1
K Following Several Power Cuts Can Only work in Safe Mode Using Outlook 0
S One host - several emailadresse Using Outlook 1
S renaming several subject lines at one time Using Outlook 1
V How change Contacts to using several letters? Using Outlook 1
M Several Problems using Outlook Using Outlook 3
B Recurring meeting times off by several hours Exchange Server Administration 5
R How Do I Merge Several PST Files? Using Outlook 4
S Mac Outlook 365 Questions Using Outlook 0
P Questions On Crashing, Sluggish, and Configurations Using Outlook 1
J Diane's Delay Delivery at Specific Times Questions Outlook VBA and Custom Forms 7
D Outlook for Android Questions Using Outlook 8
P Moving PST file questions Using Outlook 3
Y PST file questions Using Outlook 1
D Questions related to usage of webpage in outlook Using Outlook 1
G Questions on creating Outlook forms Using Outlook 0
O x86 vs. x64 Sql Server 08 Dbase Questions BCM (Business Contact Manager) 2
Jennifer Murphy Questions about ANSI-Unicode PST conversion article Using Outlook 2
J Multiple Outlook questions Using Outlook 2
P Field option selection resulting into multiple questions BCM (Business Contact Manager) 0
S Questions about Calendar Notifications Using Outlook 1
H Couple of 2007 Calendar questions Using Outlook 1
K CPA - Office 2010 - 64 bit Questions Using Outlook 1
S Couple of questions related to calender Using Outlook 1
S Seperating email accounts, Syncronizing, and a few newbie questions Using Outlook 5
T Outlook 2010 Mutliple Exchange Accounts SET UP QUESTIONS Using Outlook 4
E Questions on the OutlookRibbonXCS example Outlook VBA and Custom Forms 4
T Ribbon Control questions Outlook VBA and Custom Forms 7
K Scraping outlook emails (2 questions) Outlook VBA and Custom Forms 1
M regarding legacy contact cards Using Outlook 2
M regarding the Create Contacts From Messages code Using Outlook 8
D a general question regarding data files Using Outlook 3
S Question regarding contact links Exchange Server Administration 37
T Regarding Outlook addin Outlook VBA and Custom Forms 1
