Column view fonts
Nan
I wanted to make the fonts larger for my task view.
While in the column view I went to View, View Settings, Other Settings - Fonts and Other Table View Settings and changed Column Font, Row Font and AutoPreview Font all from 8 pt to 10 pt and clicked all the OKs.
The tasks that are in red cause they are overdo don't change. Only new tasks changed/got larger. Any suggestions (other than telling me to finish my tasks! :)
Outlook 2010 - single user, no Exchange involved.
On Win10 OS
Nan
Thanks! So can it be changed? I Googled 'conditional formatting' and found it (had never used it before and wasn't aware of where it was) went to View, View Settings, Conditional Formatting and the Font button was clickable and showed it was at 8 pt so I clicked, went in and changed it to 10 pt but nothing happened. Any suggestions?
Nan
Ignore previous message. I got it. I didn't realize that I had to highlight each case and set the fonts one at a time. All cases were ckd so I thought I was resetting it for all those checked above. I probably should have realized that Outlook would let us choose different things for different statuses. Anyway, it's all set now. It was just too small for me to read this stuff on the screen.
I have a killer app idea someone ought to create and sell. Since the population is aging, and app that goes into our applications and increases all the fonts! (Just kidding).
Actually... that might be a good idea. Probably not practical though.
R Renaming Column Heading in Contacts view Using Outlook 6
C placing contact and business phone column in task view Using Outlook 1
T Can't reposition "Flag Status" column Using Outlook 0
P Posts in Folder No Longer Group by Conversation Column After Search Using Outlook 0
O Tasks - Is there a postponed date column? Using Outlook 7
O How to display senders email address (column) Using Outlook 1
D Column for To Email Address Using Outlook 0
H "Advanced find: column for full folder path? Using Outlook 1
A Can't add a column called "name" to Inbox? Using Outlook 1
D Email Icon Column Using Outlook 2
H SQL update column BCM (Business Contact Manager) 0
C How to copy same text header to multiple emails with custom text column Using Outlook 10
G Wrong display name in from column when removing pf replication Exchange Server Administration 1
T Column Header Keyboard Shortcut Available? Using Outlook 5
H Calendar column of time without date? Using Outlook 0
K Sent folder only shows "From", not "To" column Using Outlook 1
S Outlook 2007 Sort Column Shading Using Outlook 1
J From column changes when message is read Using Outlook 1
A How to replace column title in address book Using Outlook 1
B Populating Additional Outlook Column with Date \ Time Using Outlook 0
J Outlook 2010 Inbox sort FROM column not working Using Outlook 29
S Custom Yes/No column field Outlook VBA and Custom Forms 2
Commodore MHT files (from "View in browser") Using Outlook 7
J Split reading view with history Using Outlook 2
P Calendar Day View only shows 1 all day event Using Outlook 0
J Weekend View in Calendar Using Outlook 1
Z How to show concatenated categories in list task view? Using Outlook 2
