Unopened message in inbox deleted and not in deleted items
dave2013
dave2013
Sorry Diane got wrong information from user. Just sent user a test. After she opened it she then deleted it and it cleared from Inbox but did not show in Deleted items folder.
S Unable to extract text from an Outlook email message Using Outlook 2
R Outlook 2016 Message-ID oddity/inconsistency? Using Outlook 7
J Implement Keywords based on body message Outlook VBA and Custom Forms 0
C must select message to trigger safe list Using Outlook 3
A Flag Message for Follow Up after sending Outlook VBA and Custom Forms 1
C Why won't Title display in message list? Using Outlook 1
icacream content in this message could not be downloaded.... Using Outlook 2
R Warn before sending message Outlook VBA and Custom Forms 4
M Message list font changed after update Using Outlook 2
T Change the selected Message in the Outlook window Outlook VBA and Custom Forms 2
evdbogaard Reply with only last message cited Using Outlook 1
T O365 and Office Message Encryption Exchange Server Administration 2
D Outlook Message Window Changes Size and Position Using Outlook 1
P Message List Font Changed Using Outlook 6
B Search: Cannot find which Folder Contains a Message Using Outlook 3
E Search for folder by key in subject then move new message to related folder Outlook VBA and Custom Forms 1
D Paste Excel table into Outlook message Outlook VBA and Custom Forms 6
W Message Text Using Outlook 1
J Searching message folder in Outlook 2016 Using Outlook 5
