yuvaraj
Outlook 2013 64 bit
I tried to set a rules in outlook 2013 version, but unfortunately i found the run a script option in the action pane, but while clicking on the script underlined one can't able to find My Macro Name to proceed with the rules. Could you please suggest me what will be the issues in that?
Yuvaraj
What script are you using? The name line needs to be formatted correctly - with the object in the (), not in a dim statement. (You also won't set the object in the macro - you don't use anything like set item = objApp.ActiveExplorer.Selection.Item(1) - the rule sets the item to the newly arrived item.
Public Sub scriptname (Item As Outlook.MailItem)
yuvaraj
Outlook 2013 64 bit
Thanks for the reply Diane. Below is the script which am trying to execute, please find that and let me know any issues.
Option Explicit
Public Sub Application_NewMail()
Dim olapp As Object
Dim olmapi As Object
Dim olmail As Object
Dim olitem As Object
Dim objMyInbox As Object
Dim lrow As Integer
Dim olattach As Object
Dim str As String
Dim chckSubject As Integer
Dim valSubject As String
Dim olp As Object
Dim i As Integer
Const num As Integer = 6
Const path As String = "XXXXXXXXXX"
Const emailpath As String = "XXXXXXXXXXXX"
Const olFolderInbox As Integer = 6
Set olp = CreateObject("outlook.application")
Set olmapi = olp.GetNamespace("MAPI")
Set olmail = olmapi.GetDefaultFolder(num)
Set objMyInbox = olmapi.GetDefaultFolder(olFolderInbox)
If olmail.Items.Restrict("[UNREAD]=True").Count = 0 Then
MsgBox ("No Unread mails")
For i = 1 To olmail.UnReadItemCount
For Each olitem In olmail.Items.Restrict("[UNREAD]=True")
valSubject = olitem.Subject
If valSubject Like ("*XXXXXXXXXX*") And olitem.Attachments.Count <> 0 Then
For Each olattach In olitem.Attachments
olattach.SaveAsFile path & Format(Date, "MM-dd-yyyy") & olattach.FileName
Next olattach
olitem.UnRead = False
DoEvents
olitem.Save
Next olitem
Next i
Sorry, I didn't get a chance to look at this. This Is not a run a script rule - it applies to new mail: Application_NewMail . What are you trying to do with it ? If you want to save attachments on certain messages as they arrive, see
L Outlook 2007 Macro to Run a Script From a Contact Form Using Outlook 41
B The “run a script” function stopped unexpectedly in Outlook2007 Using Outlook 6
E run script fails suddenly Using Outlook 3
L Run A Script not listed in rules wizard Outlook VBA and Custom Forms 12
L Run script rule not exectued for first few mails Outlook VBA and Custom Forms 2
D Outlook 2013 Macros only run in VB editor, not in drop down or button Outlook VBA and Custom Forms 10
B run scripts Using Outlook 1
P errors appear every time I run SCANPST Using Outlook 3
J VBA Run When Reply Outlook VBA and Custom Forms 4
Diane Poremsky Using Scanpst in Outlook Click to Run Using Outlook 0
B Can't run macro from QAT when emailing from Acrobat Outlook VBA and Custom Forms 0
