BCM conditional formatting
Picky
Outlook 2013 32 bit
Outlook.com (as MS Exchange)
Hello .
In outlook BCM I am trying to change the color of font using "Conditionally formatting" and adding a new rule. The problem is it work as long I dont close outlook. The moment I restart Outlook all the changes are gone, included the rule I added .
Is there anyway to Achieve this ? maybe any basic vba or something ?
Picky
Outlook 2013 32 bit
Picky
Outlook 2013 32 bit
Thanks for your immediate response.
Still same after activation.
Picky
Outlook 2013 32 bit
Hello.
Its still the same, resetting conditional formatting in BCM after i restart outlook.
could it be possible to get the same effect through some vba macro ? if i cannot get it to work with conditional formatting ?
You can use macros to set custom views but i don't know if it will work with bcm views.
Are you saving the custom view a a new view? If so, this could apply it, maybe. I'll need to boot a BCM VM to test.
Diane Poremsky Restoring BCM Database After Upgrading Windows New Slipstick.com Articles 0
Diane Poremsky Outlook 2016: No BCM New Slipstick.com Articles 0
Diane Poremsky BCM Errors after Upgrading to Windows 10 New Slipstick.com Articles 1
R Installing BCM BCM (Business Contact Manager) 0
G Future development of BCM BCM (Business Contact Manager) 5
A Send email from BCM BCM (Business Contact Manager) 5
