Skype for business meeting vba code
smcmaster
Outlook 2019 32-bit
Hi all,
I was trying to recycle the code in the slipstick blogpost to customize skype meeting invites, which populate a list of dial-in numbers.
I would like to take the existing list and change the font to Purple and get rid of the "English (United States)" that appears on the extreme right!
The code from the slipstick post doesn't run for me and am lost. A little help goes a long way!
Thank you in advance.
Cheers,
S McMaster
That is this one?
This line should remove the US text:
objItem.HTMLBody = Replace(objItem.HTMLBody, "English (United States)", "")
Or you can add case statements -
Case 3
strDeletePhone = "English (United States) "
strAddPhone = ""
On the purple, is that just for the hyperlinks? Change the RGB color -
.Execute
If .Found = True Then oRng.Font.Color = rgb(128,0,128)
You can get RGB colors from most color pickers (in Word or Outlook's font color picker, Image editors such as snagit) or websites like this one:
In the Color picker, if you know the hex value you can type it in the hex field and tab out - the RGB color code will update.
P Skype contact icons have disappeared at the bottom of email and meeting objects Using Outlook 2
Commodore Is Outlook 2013 still connected to Skype? Using Outlook 2
iwshim Skype tool bar in quick access ribon Using Outlook 1
Commodore Skype and contacts security/privacy Using Outlook 1
B Importing business card into Outlook for SIgnature Using Outlook 1
J Make business address defulkt in cureent not new contacts Using Outlook 1
P How to filter primary contacts in business contact manager BCM (Business Contact Manager) 0
F Set (flagged) reminder for next business day Using Outlook 4
C Business Contact Manager Using Outlook 3
E Apply customized Business Card for all users Outlook VBA and Custom Forms 0
Diane Poremsky How to Process Mail After Business Hours New Slipstick.com Articles 0
Diane Poremsky How to Always Process Mail After Business Hours New Slipstick.com Articles 0
Diane Poremsky Project and Business Process Management Tools New Slipstick.com Articles 0
B Business Connectivity Service BCM (Business Contact Manager) 4
O Calendar and business contact manager Using Outlook 0
N Select Existing BCM Business Contact in C# application Using Outlook 0
N BCM suddenly crashed and not able to view specific business contact. Using Outlook 1
M Adding fields to Task in Outlook Home and Business 2010 Outlook VBA and Custom Forms 7
D screwy behavior Business Card - Outlook 2013 Using Outlook 8
J USA in Business Card View Using Outlook 4
stephenjones Adding a business account to Outlook Using Outlook 1
S Can't send messages using Outlook 2007 from a business email Using Outlook 3
T Business Projects question BCM (Business Contact Manager) 0
J Office 365 small business/Outlook 2013 issues Using Outlook.com accounts in Outlook 1
T client addin deletes all business contacts BCM (Business Contact Manager) 1
L Business Contact Mnager losing contact details BCM (Business Contact Manager) 1
pedropimenta@netcabo.pt Sync Business contacts with Icloud contacts BCM (Business Contact Manager) 1
C Trying to move my Business Contact Manager ver. 2003 to BCM ver. 2010 Using Outlook 3
D opening Word Document in a business contact? BCM (Business Contact Manager) 3
M PST large - Imap gmail business Using Outlook 0
E No projects appearing in 'business projects' for bcm Using Outlook 0
A receive error when create new business contact BCM (Business Contact Manager) 14
M Looking for trainer in Business Contact Manager BCM (Business Contact Manager) 0
C Business Con Mgr - E-mail blast, to have a 'CC' as well as attach a document.. Exchange Server Administration 0
M Queries on Business Contact Manager (BCM) with Outlook 2013 Using Outlook 1
J Missing business contacts! BCM (Business Contact Manager) 4
V Custom UI Runtime Error in Business Contact Manager for Outlook (2013) BCM (Business Contact Manager) 6
K Business address as default mailing address Using Outlook 3
S Please help! -- Linked Account field at Business Contacts tab is always empty BCM (Business Contact Manager) 1
B BCM 2010: Exporting Notes to .CSV with Business Contacts? BCM (Business Contact Manager) 3
E Macro to export BCM business data to CSV file BCM (Business Contact Manager) 1
P Using BCM2010 Business Projects as SharePoint 2007 Data Source BCM (Business Contact Manager) 3
R "business contact manager logon failure server is in single user mode" - HELP! BCM (Business Contact Manager) 4
