Inbox column color coding
dawondr
Outlook 2007
I have a screen shot attached. In my inbox I have new unread messages in Blue and messages I have opened are in black. To the right I have a column labeled my notes that I can type text into as either a log file, or what I need to do next with it, etc. Is it possible to have the text in that column be its own color? When my inbox gets full and the subjects are longer and with the 2 preview lines everything becomes a big jumble when you take a quick look at it. I was hoping if I can make that one column be a different Font (Purple as an example) it would help stand out. Is this possible? Just as an FYI I use Dark Green for sent mail and Red for deleted mail in addition to the Blue and black mentioned above so I cant use any those colors.
Any help or suggestions would be greatly appreciated.
Dave
A Can't add a column called "name" to Inbox? Using Outlook 1
J Outlook 2010 Inbox sort FROM column not working Using Outlook 29
C Configuring Inbox columns Using Outlook 2
J Collaborative Inbox Using Outlook 1
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
E Outlook 2016 Inbox search bug Using Outlook 1
LolaArrabal My huge inbox folder Using Outlook 2
M Emails being sent to Inbox and IPM_Subtree Using Outlook.com accounts in Outlook 4
S Accepting meeting request from calendar keeps the meeting request in the inbox Using Outlook 2
E Inbox field customization Using Outlook 1
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
Diane Poremsky Category Color doesn't Display in Inbox Using Outlook 0
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
