Is it possible it set the fonts used to read incoming mail
You have the word object model selected in References, correct? I only get the error when I don't have word set in references.
Try unticking word object library, click Ok then reselect it.
e_a_g_l_e_p_i
That worked ! no errors. It asked me to name it so I did and it opened another window with the name I created. Now I have to create a certificate correct? I'll go back to your tutorial and follow it.
Thanks Diane
You don't have to sign it - I never do, because I'm constantly testing macros and would need to resign it after every edit. But if you are done editing, you can sign it then set the security level to only allow signed macros.
e_a_g_l_e_p_i
Unfortunately I can't get it to work, thought I did but still getting errors. Is there a third party that allows to set incoming email size for all emails that works well?
jessewalter375
Outlook 2019 64-bit
Exchange Server 2013
To change the default font in Outlook :
From the File tab, select Options. Select Mail. Click Stationery and Fonts. Make your desired changes to new mail messages, replying or forwarding messages, and/or composing and reading plain text messages.
Hope this information helps you.
D Is it possible to set up an email rule for a user based on alias address? Exchange Server Administration 3
D Is it possible to set a message as sent programatically? Outlook VBA and Custom Forms 1
T Outlook 2013 Possible interference by Telstra ISP with Hotmail Password Using Outlook.com accounts in Outlook 1
e_a_g_l_e_p_i Is it possible to transfer things from one calendar to another Using Outlook 2
V Is it possible to collect statistics from Outlook forms? Outlook VBA and Custom Forms 1
S Is it possible to cusstomise selectable Options in Kalander. Outlook VBA and Custom Forms 1
J Is it no longer possible to suppress Outlook 2019 Invalid Certificate name mismatch security alert via Registry? Using Outlook 1
semnaitik Is it possible to recover content from a 0KB PST file? Using Outlook 3
J Is this possible to do with a macro? Outlook VBA and Custom Forms 17
D Is it possible to automatically send an email when it is moved to a folder? Exchange Server Administration 1
T Exchange setup not possible with outlook.de username Using Outlook.com accounts in Outlook 0
H Is it possible to create a view that only show the first task in a list? Using Outlook 1
H Is It Possible to See Who Has Viewed My Calendar in Exchange? Using Outlook 2
C in outlook 2007-Contact Group-One name have 3 mail id-its possible? Using Outlook 3
J convert .pst to .eml, how is it possible? Using Outlook 1
S Is it possible to recover a permanently deleted email from my .OST file? Using Outlook 0
M Is it possible to restore deleted webmail to server? Using Outlook 3
P Is it possible to write a macro to email to all addresses of selected contacts? Using Outlook 1
D is it possible to have both a POP and IMAP account in Outlook 2013? Using Outlook 5
P Is it possible to sort emails by COUNT of "From" field? Using Outlook 2
Justo Horrillo It's possible to modify the behaviour of the conversation option? Using Outlook 2
S Possible to link to ics file without importing? Using Outlook 4
O Script to move emails to a folder based on various possible keywords Outlook VBA and Custom Forms 11
B Is it possible with Outlook form Outlook VBA and Custom Forms 5
Steve Jacobs Possible to configure TNEF options based on *sender*? Exchange Server Administration 3
S Is it possible to backup Outlook.com/Outlook 2013 Email & Calendar info? Using Outlook.com accounts in Outlook 3
O Is it possible to go from BCM Office 13 back to BCM Office 2010? BCM (Business Contact Manager) 1
E Show field from account on contact form - possible? BCM (Business Contact Manager) 1
A Possible to modify people preview window? Using Outlook 1
T OL BCM 2007 - Possible to migrate SQL Server Express 2012 ? BCM (Business Contact Manager) 2
V Name of attachment in replies (HTML) - possible?? Using Outlook 12
C Is it possible: List of URL fields BCM (Business Contact Manager) 0
D Frequently used response short cut possible macro Using Outlook 1
Commodore Exporting all contacts to VCF files possible? Using Outlook 4
M I'd like to alter the appointment balloons. Possible? Using Outlook 6
J Is it possible to highlight a folder in Outlook 2007? Using Outlook 2
L I want ONE calendar if possible with no overlaying Using Outlook 1
S possible to access my PST file on the Internet Using Outlook 2
N Outlook Rules - is this possible? Using Outlook 3
G Possible to create reports that return contacts based on account criteria? BCM (Business Contact Manager) 0
