Inbox didn't got read
alvinoo
Outlook 2019 64-bit
Hi there,
Is there anything wrong with this code.
It seems that it only pick up the first two Orange Category and Flag For Follow up email.
3rd and 4th email didn't got picked up.
Sub FollowUpEmail() Dim objNS As Outlook.NameSpace, objFolder As Outlook.MAPIFolder, _ objResItem As Object, objMail As MailItem, objResendMail As MailItem, _ olFldrItms As Items Set objNS = GetNamespace("MAPI") Set objFolder = _ objNS.Folders.Item("xxxx").Folders("Inbox") ' folders of your current account Set olFldrItms = objFolder.Items Set objResItems = _ olFldrItms.Restrict("[Categories] = 'Orange category' and [FlagRequest] ='Follow Up'") For Each objMail In objResItems Set objResendMail = objMail.ReplyAll 'attachment is copied CopyAttachments objMail, objResendMail 'immediately shift to sent item when first sent in vba With objResendMail .HTMLBody = _ "Follow up request" & vbCrLf _ & objResendMail.HTMLBody '.Importance = olImportanceHigh .Categories = "Orange category" .FlagRequest = "Follow up" .Display End With With objMail 'flag items as complete and move to the sent items objMail.Categories = "" objMail.FlagStatus = olFlagComplete objMail.Save End With Next End Sub
C Configuring Inbox columns Using Outlook 2
J Collaborative Inbox Using Outlook 1
P Outlook Mobile App Doesn't Refresh Inbox Using Outlook 0
T Inbox Sub-Folder - Web Using Outlook 1
E Outlook 2016 Inbox search bug Using Outlook 1
LolaArrabal My huge inbox folder Using Outlook 2
M Emails being sent to Inbox and IPM_Subtree Using Outlook.com accounts in Outlook 4
S Accepting meeting request from calendar keeps the meeting request in the inbox Using Outlook 2
E Inbox field customization Using Outlook 1
M Ensure the same inbox view across multiple outlook instances Using Outlook.com accounts in Outlook 7
Diane Poremsky Category Color doesn't Display in Inbox Using Outlook 0
E How to find or recover Lost e-mails within a folder under Inbox? Using Outlook 2
A Can't add a column called "name" to Inbox? Using Outlook 1
V Not displaying newest messages in Inbox Using Outlook 10
