Clipboard Resize Issue
Albert
Windows 10 Pro 64 bit
MS Office/Outlook 2016 Business Build 13127.20408 32 bit
I start a clipboard in Word. I resize it.
I open a new email and now, I have to resize the clipboard again. I send the email. Open another new email to compose and have to resize the clipboard again.
The original resized clipboard in Word stays resized.
Previously, once I resized the clipboard in either word or outlook, it stayed.
Please help.
Albert
Thx for the reply
Yes, only in Outlook.
I have tried:
open a new message, adjust the clipboard then close the message
pen a new message, adjust the clipboard, save the message, then close the message and open back up.
The resize of the clipboard does not stick.
This works here - at least until I close the outlook. Then it reverts to the left, with the width smaller. I don't see a registry key that saves the setting.
Albert
Yes, I agree. this is the issue I'm having.
It never did this before.
There is no use in resizing or moving, if, when you send another email, outlook reverts it back to the default size.
Albert
Is there a place I can go to inform MS of this issue?
Here it stays as long as I keep outlook open (which is mostly 24/7). If you have help > feedback or contact support, use it. I'll also mention it to my contacts on the product team.
BTW - Which version and build of Outlook are you using? See File, Office Account for the information.
Albert
I use the clipboard for individual emails. so every time I start an email, I have to resize.
Office 2016 pro 32 bit build 13127.20408
Windows 10 pro 64 bit
M Retrieve data from GAL and put it in Clipboard Using Outlook 1
Diane Poremsky Paste clipboard contents using VBA New Slipstick.com Articles 0
F How can i copy the mail subject and the link to the mail to th clipboard? Outlook VBA and Custom Forms 3
R Outlook 2013 VBA I want to put the entire message to clipboard Using Outlook 5
V Screenshots / Clipboard images disappear after sending Using Outlook 3
M Clipboard Manager Not showing in Outlook 2010 on Start Using Outlook 8
I Clipboard paste in macro Using Outlook 14
S ClipMate clipboard connection Outlook Wishlist 1
K How to copy Contact Item to Clipboard and Paste as "VCF Link? Outlook VBA and Custom Forms 4
Diane Poremsky Move and Resize Office 365 Launcher Tiles New Slipstick.com Articles 0
icacream Stopping Outlook to resize photos... Using Outlook 2
D Unable to resize image in email signature Using Outlook 4
M How to resize the instant search pane on click on the icon to expand/ Outlook VBA and Custom Forms 1
M Outlook 2003 Plugin not receiving resize events Outlook VBA and Custom Forms 1
D hide messege issue Using Outlook 1
B Outllok 2007 License Expired issue Using Outlook 0
M Calendar Time Zone issue Using Outlook 0
B My outlook calendar edit issue Outlook VBA and Custom Forms 0
D Unusual calendar issue Exchange Server Administration 0
D Multiple Accounts Issue Receiving Emails in 2016 Using Outlook 0
B Winmail.dat Issue Using Outlook.com accounts in Outlook 0
tswatek Issue with where Outlook saves new contacts Using Outlook 3
K Outlook with MDaemon Connectivity Issue Using Outlook 4
G .ost file corrupted / solved the issue with some posts already said, but .ost file is corrupted agai Using Outlook 2
D Resizing issue for message field Outlook VBA and Custom Forms 0
P Outlook hanging issue Using Outlook 0
K Outlook 2013 calendar issue with Outlook.com Using Outlook.com accounts in Outlook 2
J Favorites in Public Folders issue Outlook VBA and Custom Forms 0
K Insert screenshots issue Using Outlook 2
B Sub Calendar-Color Coding Issue Using Outlook 4
T Using Outlook 2007 with Comcast (.pst inbox issue) Using Outlook 1
Brendan.Z Outlook 2013 signature editing issue Using Outlook 3
F Custom contact form icon issue Using Outlook 1
