How to create fixed signatures for aliases that process through GMAIL?
Ardilla
Outlook 2019 64-bit
I used your VBA macro to ensure that all my Gmail aliases received in Outlook are answered with the "from" address it was sent to. Using a Gmail Master Account: Reply Using the Correct Account - This is working great!
My issue now is how to add a fixed signature for these aliases. Outlook only allows the ability to create signatures for mail accounts.
Thanks for your help!
C Can't create Outlook data file Outlook Wishlist 0
Diane Poremsky Create a Task when a Message is Flagged Using Outlook 0
Diane Poremsky Create a custom field for Outlook messages Using Outlook 0
Mark White vba to create a shared mailbox folder Outlook VBA and Custom Forms 3
Diane Poremsky Automatically create a task when sending a message Using Outlook 0
Diane Poremsky Create a Custom Numbering Field for Outlook messages Using Outlook 0
Diane Poremsky Create a Series of Tasks using VBA Using Outlook 0
