iCloud add in problems
AllanBlacher
My iCloud add-in is disabled and will not re-enable itself when I try to check the relevant box in Manage COM add-ins. Error message 1) says it was disabled by the user after a Data Execution Prevention failure and 2) (on the manage screen) The add-in is enabled by your system administrator but disabled because it prevented Outlook from functioning correctly.
I am using Win 10 and office 365. iCloud is not listed in 'slow and disabled' add-ins list.
Diane Poremsky was hugely helpful resolved a similar, but slightly different, problem for me some months ago now....I have tried what she suggested, and what worked last time, editing the HKEY to 3 but it does not cause the add-in to load. I've also run the slipstick option to alter the registry but that too doesn't seem to have worked this time.
I tried uninstalling and re-installing iCloud but the problem has continued.
I'd really appreciate some help!!!
That means it there is a serious error - the key will prevent outlook from disabling it for loading slow and minor crashes, but not for ones that prevent outlook from loading.
Which iCloud are you using - the apple download or the one from the Microsoft store?
Try this: Sign out of iCloud, uninstall it. Repair office, reinstall iCloud.
AllanBlacher
Hi Diane, I am so pleased this has reached you personally - having had the benefit of your input before, I have a strong sense that if you can't sort it, no-one can!
1) I am using iCloud v12.0 and I'm pretty sure its from apple I had no idea they might be different. If I proceed, which one should I use?
2) I can easily uninstall iCloud and then reinstall it but can you please tell me what I do to repair office. I am not by any means technically skilled.
3) Is there a paid option i.e. is it something you could do remotely for a fee? Forgive me if I am going beyond proper boundaries in asking. Aside from the cost, my only other concern is whether you can gain access to my pc.
Regds Allan
AllanBlacher
Hi Diane, I hope you might see the message I posted above following your earlier response. I do look forward to hearing from you.
Regds. Allan
It is from apple, but distributed through the windows app store.
There is a download from apple, ostensively for older versions of Windows. It works with Win 10 too. It's version 7.xx
To repair your Office installation, right click on the start menu and choose Apps & Features, find and select the Office installation. Choose Modify then select the Quick repair option. Use the Quick Repair option first as it will fix many things and complete fairly quickly.
If it doesn't help, use the Online Repair option to uninstall Office and reinstall Office. It will not delete your existing Office settings or your Outlook profile and data files.
When you uninstall iCloud you need to sign out of iCloud first, so it removes the iCloud data files from outlook.
A iCloud add-on for Outlook: Reminder for new appointment is set to 'None' by default. How to change? Using Outlook 6
V Outlook 2013 - iCloud add-in creates issues Using Outlook 4
L Outlook 2007 does not start with Apple iCloud-Add-In activated Using Outlook 2
V Outlook 2016 Outlook-2016 and iCloud for Windows - Problems Using Outlook 10
B iCloud for Windows 11.2 disconnects by itself after 30-45 minutes Using Outlook 9
W Looks like the folder below has been deleted: "iCloud\Calendar" Using Outlook 1
Commodore iCloud mail with two-factor authentication Using Outlook 7
V iCloud Calendar invitations not sending Using Outlook 3
Horsepower Need iCloud mail only Using Outlook 1
Diane Poremsky iCloud, Outlook 2016, and Windows 10 Using Outlook 0
M icloud removed my contacts Using Outlook 7
H Can't connect to icloud Using Outlook 0
Diane Poremsky Online Services in Outlook: Gmail, Yahoo, iCloud, AOL, GoDaddy Using Outlook 1
W FYI: CodeTwo Sync for iCloud is FREE now! Using Outlook 0
M Can't Delete iCloud Calendar Notifications From Outlook 2016 Using Outlook 0
makinmyway Appointments Created in iCloud Calendars Cover Contacts Field...Why? Using Outlook 3
J Issues in Canceling iCloud Configuration and Reverting to Local PST Configuration Using Outlook 0
Brendan Keeping Outlook contacts on PC after signing out of icloud Using Outlook 1
B Repairing iCloud damage Using Outlook 1
David Langer iCloud 5.0 for Windows and Outlook 2016 Using Outlook 5
D iCloud for Windows v.4x Using Outlook 4
S Using iCLoud Contacts for Outlook Email Using Outlook 1
