dxfoxd
I created VBA code to automate the formatting and language selection in new e-mail messages and replies to e-mails, because I send a lot of e-mail and in different languages.
One irritating issue which I cannot resolve is the spell check that is performed on the e-mail subject. My default setting in Outlook options for languages is Dutch and all other languages I use are installed in the second list (editing languages). The default Outlook display option is Dutch, but I don't think that this setting is affecting (of should affect) the spell checker.
Setting the language for the e-mail body text happens flawless, either applied to the selected text or from the start of the message until the applies signature bookmark. However, the language used in the subject field is not touched and as a result, every false positive in the spell check requires me to perform unnecessary clicks. Even sending a e-mail manually, selecting the subject text, setting the correct language, still shows a misspelling (see screenshot).
Is it possible to change the language of the subject field in VBA and if not, to which setting is it the language in the subject field related?
I appreciate your help!
Peter
dxfoxd
Thx Diane. But which property to set here? I cannot find any property related to the header language in the mailitem itself.
That's what I'm not sure - but will try to find out.
L Spell-check dictionary confusion Using Outlook 0
C Unusual Signature & Spell Check Query Using Outlook 1
M Spell Checker Changes -- Not as Predictive as Previously Using Outlook 3
M spell checker insanity Outlook VBA and Custom Forms 1
A how to disable spell checker Outlook VBA and Custom Forms 4
Victor.Ayala Automated way to check the option "Show this folder as an email Address Book" Outlook VBA and Custom Forms 0
S How to export urls from email to excel and check the status of the url ? Using Outlook 5
S Outlook to check for specific text Outlook VBA and Custom Forms 3
A Check for words in subject header before sending email Outlook VBA and Custom Forms 4
I Check if sent email has been replied Outlook VBA and Custom Forms 1
R Macro to check file name with outlook address book Outlook VBA and Custom Forms 0
Diane Poremsky Check Contacts before moving them to Hotmail Contacts folder Using Outlook 0
Diane Poremsky Check for missing attachments before sending a message Using Outlook 1
R Outlook 2010 Modify Style "Do not check spelling or grammar" not saving Outlook VBA and Custom Forms 0
K check for sender, follow to my personal adress and delete the sent folder. Outlook VBA and Custom Forms 1
J Send and Receive Button - only check default account? Using Outlook 1
A Check for attachment code not working Outlook VBA and Custom Forms 1
Diane Poremsky Check Message Size Before Sending Using Outlook 0
B Check for different domains macro to be triggered by specific domains only Outlook VBA and Custom Forms 2
V Check/convert to emailaddresses Outlook VBA and Custom Forms 11
JorgeDario how to check a MailItem has a digital signature (SMIME) with vba? Outlook VBA and Custom Forms 1
O Unable to check name. Using Outlook 3
R Outlook Custom form check if there an attachment Outlook VBA and Custom Forms 2
L Trying to check for the absence of mail. Outlook VBA and Custom Forms 1
S Check if two organisition is added then i have to give managers passward creteria to send mail Using Outlook 1
Peter H Williams check for new email automaticlly Using Outlook 12
M Calendar navigation displays previous field records.check calendar is shared.. Using Outlook 3
A Can Rule Check Category Contact is assigned? Using Outlook 1
T Outlook 2007 forms: Check boxes and free text boxes not retaining data Using Outlook 1
L check if send message appears in SendItems forder before moving Using Outlook 0
C Create a rule to only check new content in email - disregard original content Using Outlook 3
M Outlook Rules check for new line character Using Outlook 1
G Outlook rule check for messages not received Outlook VBA and Custom Forms 2
E Outlook could not create the work file. Check the temp environment variable Using Outlook 8
B Custom real time, time format check Outlook VBA and Custom Forms 1
B BCM shuts down everytime I try to import/export or check for error BCM (Business Contact Manager) 10
D Check whether mail item is proper for sending or not Outlook VBA and Custom Forms 5
P Check for the distribution list existence Outlook VBA and Custom Forms 1
H out to check whether outlook configured or not Outlook VBA and Custom Forms 1
M Check Profile info Outlook VBA and Custom Forms 1
L Check sent email and reply if have specific words Outlook VBA and Custom Forms 2
Z Check if email was sent Outlook VBA and Custom Forms 1
Z All Day Event Check Box Outlook VBA and Custom Forms 1
