Capture Sender's Display name and Address
Ross
Outlook 2016 64 bit
Exchange Server 2007
Why is this code not displaying the sender display name and email address? Is it because I'm on MS Exchange?
Option Explicit
Private Sub SendEmail()
Dim OutApp As Object
Dim OutMail As Object
Dim sBody As String
Dim sEmailBody As String
Dim sSenderName As String
Dim sSenderEmail As String
Set OutApp = CreateObject("Outlook.Application")
Set OutMail = OutApp.CreateItem(0)
sEmailBody = "Testing"
With OutMail
.To = "test@yahoo.com"
.Subject = "Test"
.display
sBody = OutMail.HTMLBody
With OutMail
.HTMLBody = sEmailBody & sBody
.display
sSenderName = OutMail.sendername
sSenderEmail = OutMail.sendername
Debug.Print "Name: " & sSenderName _
& Chr(10) & "Email: " & sSenderEmail
Set OutMail = Nothing
Set OutApp = Nothing
Not really because of exchange - but because senderemail is incoming and the name and address aren't set when you prepare a message.
You can get the values as the message is sent (using an itemsend macro) :
sSenderName = OutMail.SendUsingAccount
sSenderEmail = OutMail.SenderEmailAddress
Debug.Print "Name: " & OutMail.SendUsingAccount & _
Chr(10) & "Email: " & OutMail.SenderEmailAddress
This will get you the account name and address - which in current versions, is the email address for both when you use Exchange - it can be changed for pop and imap.
Debug.Print Item.SendUsingAccount
Debug.Print Item.SenderEmailAddress
Ross
Outlook 2016 64 bit
Thank you. This will work.
I Capture incoming emails Outlook VBA and Custom Forms 1
A Capture network traffic in IE to file Outlook VBA and Custom Forms 5
JorgeDario How to capture and save the text, when responding a MailItem? Outlook VBA and Custom Forms 3
G Capture "forward event" ? Outlook VBA and Custom Forms 11
J VBA Form in Outlook to capture data and complile a mail Outlook VBA and Custom Forms 2
A how to capture events for next item Outlook VBA and Custom Forms 10
B Capture Inbound E-mail Subject with VBA Outlook VBA and Custom Forms 4
R How to capture a Mailitem Event Outlook VBA and Custom Forms 3
A how to capture outlook 2007 events Outlook VBA and Custom Forms 4
T Some way to capture who marks an email as read Outlook VBA and Custom Forms 1
C Event Capture - Item Context Menu (Delete). Can you hook it? Outlook VBA and Custom Forms 1
J Outlook 2016 How tell Outlook not to trust sender? Using Outlook 1
M Screen Scrape Sender IP Address Outlook VBA and Custom Forms 6
S Meeting Invite arrives from Wrong ("send-as") Sender Using Outlook 1
D Moving Emails Based on Recipient/Sender Outlook VBA and Custom Forms 4
A Sort emails into subfolders based on sender and deleting emails automatically Outlook VBA and Custom Forms 3
Ed Sheehan Unusual behaviour in setting Sender (Outlook 2016) Outlook VBA and Custom Forms 4
M Move new mail to folder based on sender address Outlook VBA and Custom Forms 2
D Inserting sender name and address with vba Outlook VBA and Custom Forms 1
M Blocked Sender List @Domain Not Working Using Outlook 0
B Can't expose sender email address when linking outlook to access Using Outlook 3
Diane Poremsky Use VBA to create an Outlook Search Folder for Sender Using Outlook 0
K Extract email to excel from a specific sender Outlook VBA and Custom Forms 3
O See recent emails from a sender Using Outlook 2
S announce email sender and subject when new email arrives... Using Outlook 7
K check for sender, follow to my personal adress and delete the sent folder. Outlook VBA and Custom Forms 1
P Mail delivery failed returning message to sender Using Outlook 1
K Outlook moves sender's mail, but there is no rule Using Outlook 0
Diane Poremsky Sort messages by Sender domain Using Outlook 1
B Find related messages to sender Outlook VBA and Custom Forms 7
